Blinker not working, HELP!!
Old May 21, 2003 | 06:55 AM
SSDriver's Avatar
Default Blinker not working, HELP!!
Well for the last 2 weeks the right blinker has not worked. When I got to turn the Right blinker on the arm acts as normal but the turn light STAYS lit up and does not flash. The blink doesnt light up at all outside of the car. What could be the problem? If it is the blinker relay, where is it on my car? Thanks for your time and help.
-William
Old May 21, 2003 | 12:28 PM
Nightfall's Avatar
Default Re: Blinker not working, HELP!!
You have a bulb or part of a bulb burned out. Replace your bulb and viola, fixed!
Old May 21, 2003 | 12:42 PM
OctaneZ28's Avatar
Yep, a non-blinking turn signal means your front turn signal bulb is burnt out.
And also, just for information purposes, a quickly-blinking turn signal means a rear bulb is burnt out.
Old May 21, 2003 | 02:03 PM
SSDriver's Avatar
Wow Thanks guys this is great news. I'm so glad to find out its just a bulb. Thanks A LOT.
-William
Old Mar 13, 2004 | 02:09 PM
Bad30th's Avatar
Dug this post back up with search - this helped me today immensely !
I was that my turn signals quit working. Hazards worked, but L/R signal staying lit with no "blink".
I'll check the bulbs, they're factory from '99 so that's prolly it.
Thanks guys !
Rob (Bad30th)
Old Mar 13, 2004 | 11:38 PM
VIP1's Avatar
Copy & Paste Moderator
If all the bulbs and sockets check out then the flasher has probably gone bad. There is a flasher for the turn signals and a separate flasher for the hazards.
--VIP1
Old Mar 14, 2004 | 07:37 AM
WhiteBird00's Avatar
Ungrounded Moderator
There is some misinformation going around about turn signal problems...
1. When a bulb is burned out on either the front or the back, that side will stop flashing - there is no way (such as faster flashing) to tell whether the bad bulb is front or back without getting out and looking for the one that doesn't light. The turn signal flasher works somewhat like a thermostat - electric current passing through the contacts causes the bimetal arm to heat up and break contact. It then cools and makes contact again. When any bulb is burned out there isn't enough current flow to the rest of the bulbs on that side to make the arm heat up enough to break the contact so the remaining lights just stay on.
2. If one side flashes but the other side doesn't then there is never any reason to change the flasher. No matter what other testing you've done - do it again because the flasher can't be the problem. The same flasher operates both sides of the turn signals so if either side works then the flasher must be OK. There is a separate flasher for the hazard lights which can be very helpful when looking for a problem. Turn on the hazard lights (which will almost always flash because there are twice as many bulbs drawing current) and walk around the car looking for the light that doesn't work. Don't forget that Firebirds have two bulbs on each side at the back that should flash. When you find the one that doesn't light, check the bulb first, then the socket for a bad ground, and if you still haven't found the cause start checking for broken connections along the line.
Old Jul 27, 2007 | 05:11 PM
tee-boy's Avatar
Default ddd
I've got the inevitable turn signal problem and found this post. My right front signal doesn't blink. Bulb is ok. Left turn signal is OK, so can't be flasher according to this post. So I assume it's the socket. I use test light w/ good ground on the frame and make contact w/ all three wires to socket and all I get is a steady light on one of the wires. Neither of the other two wires provide any light much less an intermittent light. Any ideas?
Old Jul 27, 2007 | 05:25 PM
Disturbed Bird's Avatar
well someone has to say it. check your blinker fluid!
Old Jul 27, 2007 | 07:18 PM
VIP1's Avatar
https://ls1tech.com/forums/showpost....18&postcount=7
Old Jul 27, 2007 | 07:58 PM
presto_z's Avatar
ya my blinkers were so loud and slow.. i had over 200,000 blinks on the stock non synthetic fluid , i flushed out the blinker system with this and now they work great
http://kalecoauto.com/index.php?main...&products_id=6
