i am a complete and utter newb about stereos
i have an 02 ta non monsoon system. id like to upgrade my head unit and speakers. im not looking for competetion(sp) just something that has a little bump to it. more or less im looking for some suggestions as far as head units and speakers. the head unit doesnt have to do anything fancy with the exception of having an ipod hookup(not to fancy anymore in my book). thanks.
edit im thinking about getting an mtx thunderform sub (amplified) just for some bass. just would like an opinion of this if you know anyone who has one or ever had one yourself.
Originally Posted by WhiteBird00
What makes you say it's a non-Monsoon system? My option list shows the 02 T/A came with Monsoon as standard equipment and that the base audio system was only available in V6 Firebirds that year.
i also do not have tcs on mine either so it may have been ordered from the factory without these options....i dunno
Ungrounded Moderator
That's true - hatch speakers or separate tweeters in the doors (Firebirds only) are a good way to tell. The definitive answer is to check for option code W54 (cassette) or W55 (CD) on the door sticker. It doesn't really matter if you're only upgrading the head unit but it makes a difference in replacement speaker selection.
Originally Posted by import_raper
As far as I know, a Monsoon system will have speakers in the hatch.
Originally Posted by 96ta
i was under the impression they all had speakers in the hatch area even my 96 ta had them there.....
No, the base audio system had speakers in the doors and the sail panels (next to the rear seat) but none in the hatch area. There was a "premium" 10-speaker sound system available in earlier Firebirds that was very similar to the Monsoon and had speakers in the hatch area. Your 96 T/A must have had that optional system.
The sail panel speakers on the base system were just ordinary speakers (actually, high impedance 10-ohm, "extended range" speakers) that could be replaced with just about any speaker on the market.
The sail panel speakers in a Monsoon system are subs that are 4-ohm dual voice coil and receive a low-pass filtered signal from the Monsoon amp. Unless rewired, you will get nothing but bass from any speakers you install there. That could explain the problem with the full-range Alpine speakers you had installed.
hmm interesting well i have speakers in my hatch and i have a cd player with no cassette deck or changer and the component speakers up front. if i have all that then why is my headunit labeled as a monsoon system doesnt make sense to me
so in order to prevent screwing up the next set of speakers i get i should either go back with some delco model ones or replace the whole system.....
https://ls1tech.com/forums/wiring-stereo-electronics/729181-7kv-2-install.html
https://ls1tech.com/forums/wiring-stereo-electronics/639901-install-guide-w-pics-upgrading-factory-monsoon-subs-6-5-ones-ed-eu700s.html
another question would it be better to use (if i got a new hu) its electronic eq or buy another one? ive always liked being able to fine to the eq and i dont feel i get that with the electronic ones in the aftermarket hu's.
