Anyone with Autotrix passenger pwr window mod
Old Sep 17, 2007 | 07:27 PM
camaro_five0's Avatar
Default Anyone with Autotrix passenger pwr window mod
So I installed the wiring mod, and it didn't work. I could hear the relays clicking when I pushed the switch up and down, but the window didn't move. I double-checked my wiring, everything was according to the instructions, still no luck. Anyone have any DETAILED instructions with pics?
Old Sep 18, 2007 | 08:50 AM
rmpitzer's Avatar
Hmmmm, I followed the instructions and mine worked GREAT!
Old Sep 18, 2007 | 10:44 AM
fredmr39's Avatar
What was the condition of the windows before using this?
Old Sep 18, 2007 | 10:47 AM
rmpitzer's Avatar
That's what I'm wondering. In my case, the window was just slow.....REAL slow. Even replacing the motor didn't help. But the Autotrix fix worked great.
Old Sep 18, 2007 | 07:14 PM
Yeah both my window motors were replaced in 2005, so they're good. Maybe I just have a bad relay or something...i'll have to get the multimeter out i guess.
Old Sep 18, 2007 | 07:44 PM
RE AND CHERYL's Avatar
If you hear a click when selecting up and down then the relays are good. Do you have good power? The relays and the window motors operate off seperate power sources. Pull the pul off the window motor and while selecting up or down check for power and ground. You might have wired something wrong.
Re'
Old Sep 21, 2007 | 12:17 PM
JoeKnowsBaseball's Avatar
check the ground for the relay. remember that most of the parts in the door are made of fiberglass and won't make a ground.
and other than that from what i hear the kit comes with a relay, this one might be bad. check it on a multimeter and if it's no good you can get one at autozone for liek $5
Old Oct 23, 2007 | 04:40 PM
autotrix's Avatar
Closed ex-Sponsor Account
We check every relay before packaging to try and insure good product quality control but there are always special cases. Most of the time if the relay clicks it is ok, although I would check for the amount of voltage coming off of the switch leg of the relay to determine if it is the problem.
Installing our kit exactly like we show also plays a big role. Power and ground locations (as stated above) make a big difference.
Old Apr 20, 2008 | 11:39 AM
michaelg589's Avatar
i need directions
Old Apr 20, 2008 | 12:47 PM
98boxer's Avatar
edit: let me edit my previous post, basicly im asking will the 129 bucks, you are selling for the driver side fix my windows from getting stuck mid way? Or do i need new window motors?
I fear getting the autozone window motors cause i've read that they don't seal right at the very top?
Old Apr 20, 2008 | 09:52 PM
98boxer's Avatar
bump, bump, bump
Old Apr 29, 2008 | 04:57 PM
gnomee's Avatar
Originally Posted by 98boxer
bump, bump, bump
Missed this thread... Sorry about that.
Replacing the motor should get the window up all the way if not greasing the track should fix that.
Installing the driver and passenger side kits will make sure the windows stay functioning like they should for a long time instead of the usual 1-2 years if that.
Hope this helps. PM me if you have any more questions.
Old Apr 30, 2008 | 11:42 AM
autotrix's Avatar
The passenger side kit has been known to wake old and dying motors up although we recommend a new motor when installing any of our window motor products. Our kits will allow the window to operate correctly if all physical aspects are okay.
Old Apr 30, 2008 | 01:39 PM
rmpitzer's Avatar
Before I installed the Autotrix kit, I replaced my passenger side window motor, and it didn't help at all. It was still really slow. I bought the Autotrix kit, and it fixed the window.....to the point, I put the original motor back in, and it's like brand new again.
I'd like to speed up the driver's window, but it's not slow enough to spend $129 on.....yet.
Old Apr 30, 2008 | 02:42 PM
gnomee's Avatar
Thats great to hear!
We did our best to get the cost low on the driver side kit but having to create an express down module that would function with the kit is where the cost is.
Hopefully we can ratchet that price down over the next year or so.
Old Apr 30, 2008 | 03:11 PM
bdrussell's Avatar
What is this kit?, my passenger window is terribly slow and when I bought the car I was told they had replaced the powerwindow motors.
RustyNCA
Old Apr 30, 2008 | 05:03 PM
gnomee's Avatar
RustyNCA
The factory wiring in the f-body sends low voltage to the window motor and it causes it to wear out the motor pre-maturely.
Here are some links to more info:
https://ls1tech.com/forums/showthrea...passenger+slow
https://ls1tech.com/forums/showthrea...light=autotrix
Old May 20, 2008 | 05:48 PM
autotrix's Avatar
This kit is availible at Ws6store!
http://www.ws6project.com/user_stor/...f56066fecb1e72
Old May 24, 2008 | 03:13 PM
gnomee's Avatar
ttt...
Old May 28, 2008 | 07:01 PM
Black 99 Bird's Avatar
I need a new window motor to go with the Passenger Window Fix Kit. What do you guys recomend?
