I want a remote start...Help!
Edit: I wouldn't mind having an alarm as well. I just don't want to spend very much. So some suggestions of an alarm and remote start will be nice as well. Also, I have a A4
.at any rate.. my two cents.. i had a remote start (viper with the fancy key deal with the screen... mucho $$$) on my last truck and thought it was super cool, but it got old quick and became more problematic even more quickly.
either way.. good luck with it.
I've had remote start in 4 previous vehicles, and loved it.
There are now manual trans-compatible remote starts available as well.
The installer will make or break this though.. big time.
good luck bud
You can probably find places that do it a bit cheaper, but you get what you pay for in terms of installation.
Just to give you a pointer, I would not reccomend purchasing a unit until you find a good installer. Most installers can cut some slack on installs if you buy the equipment from them. Otherwise, many small shops will charge a "foreign equipment" charge, since it was not purchased from them.
But again, your going to cross your fingers and hope the installer has some experience under their belt.
If you think about it, for another 200$, you get a security system, and the ability to open and close your doors with the same remote. PLUS, you get a two way extended range system.
Besides, Unless you get the more expensive bypass kit, you will need to give up one of your keys to put into the box.
You don't need to buy into any of that fancy LCD keychain nonsense...the fancier they try to make it, the more likely it is to break. The $60-70 you're going to spend buying one plus whatever the cost of the VATS bypass gizmo is WAY more worth it than $500 for some Viper POS.
If you follow the wiring diagram carefully, and take care to do things right (DON'T use those stupid things that just bite into wires to connect to them, cut carefully, solder carefully and heatshrink or tape carefully, and keep yourself organized) there's no reason you won't be able to install it in a few hours on a weekend and have the wiring significantly cleaner than it will be if you go to best buy or some car stereo/alarm shop and have their "#1 installer" do it for you...that person is #1 because they cut corners and do things fast, not because they take care to do things right.
Alarms w/ keyless entry and remote start is a little different. OBDII f-bods > you'll need to buy an extra relay b/c you actually have to "wake" up the door looks in order for them to lock and unlock properly.
that bypass module for VATS is an overstated paper weight
Just some FYI, Ive seen a few people who thought they could Do it themselves end up paying 3-5 fold more because they had to have their hacked install un installed and reinstalled by people who were more knowledgable.
This isnt including the random circuits people have fried that can cost in excess of 1200$ ( Toyota Scion ECU)
A reputable shop has installers around not only for how quickly they perform installs, but in relation to how many times people come back due to problems. It wouldnt make sense in a good business plan to do a hack job and get customers out as quickly as possible, small companies will lose revenues over time.
Oh and just so you know, most of those 50$ systems you compare to the POS 500$ systems are made by the exact same manufacturer, about 95%.
