midbass
Old Jan 11, 2008 | 04:43 PM
mezmerize1's Avatar
Default midbass
does polk audio make any 6.5 100W rms midbasss speakers? or does anyone know of any good 100W rms midbass 6.5" speakers? TIA
Old Jan 11, 2008 | 05:52 PM
Eskimo's Avatar
I've got JL 6w0's in the sail panels of my car, and they are pretty good for what they are.
power ratings don't really mean a helluva lot anyway.
Old Jan 11, 2008 | 09:02 PM
KEE AUDIO's Avatar
I carry several from CDT and MA Audio however the only one that wires up like the stock one is the eD eu700. The stock Monsoon one is a dual voice coil woofer that used 2 4ohm voice coils. This bridges it down to a 2ohm load. The eu700 does require a spacer in order to fit properly in the sail panel area.
If you use a regular 4ohm midbass/midwoofer you would only use 1 pair of the wires from the Monsoon amp and cap the other 2 off.
Old Jan 11, 2008 | 09:10 PM
mezmerize1's Avatar
i'm most likely going to get a 100X4 amp. will replacing the stock amp make much of a difference in sound?
Old Jan 11, 2008 | 09:27 PM
KEE AUDIO's Avatar
For best overall sound quality going with aftermarket amplification is the best way to go. It also enables you to not have to worry yourself about the factory 2ohm this and that. You can use standard 4ohm speakers effectively. I can put together a package for you if you want that includes everything you'd need to replace your Monsoon system. I've done several including my own 98 T/A.
Old Jan 11, 2008 | 09:35 PM
mezmerize1's Avatar
thatd be great if you could set something up for me. the only thing is that i only have 375$ of my money left for speakers etc. i dont need speakers for the hatch. i was going to get all of my stuff on amazon because its pretty cheap. im not sure if I have enough money for you to put something together for me or not but any kind of help with this speaker stuff is appreciated. thanks
Old Jan 11, 2008 | 10:30 PM
Richiec77's Avatar
Then I'd recommend putting the more money to most of your money in a good set of component speakers. A good set of 6.5" components will sound very good and you won't need to worry about the sails as much.
Old Jan 11, 2008 | 10:34 PM
mezmerize1's Avatar
i was planning on getting Polk Audio db6501 components, i just need some midbass speakers that match the rms of the polks so that i only need one amp to power them.
Old Jan 11, 2008 | 10:51 PM
linegtdt52's Avatar
Default speakers
just get some mbquarts and be done with it.
I have 2 sets of polk momos and a kicker sx900.4 running them. **** is insane clean and loud
Old Jan 12, 2008 | 03:34 AM
J_Z28_T's Avatar
Default mid bass
focal is good but high
Old Jan 12, 2008 | 09:51 AM
mezmerize1's Avatar
alright, i know what im going to get. Polk Audio MMC6500 components for the front and Kicker SS-Series SSMB6 midbass drivers for the sails. for the amp ill probably be getting an MA Audio M500XE. now can I just get any amp wiring kit? from what i've read most people seem to prefer 4 gauge wire. about how long should the wires be? TIA
