Alarm goin off
Old Jan 24, 2008 | 02:44 PM
letsrun97z's Avatar
Default Alarm goin off
I was work up last night by my alarm went out and turned it off, checked the car out nothing was wrong. i set the alarm and 5sec later it goes off again. i opened and closed the trunk,hood and both doors. set the alarm and it went off again so this morning got in the car and started it and no security light came on and its still doing it?? oh and its a factory alarm
Old Jan 24, 2008 | 03:00 PM
WhiteBird00's Avatar
Ungrounded Moderator
As in the hundreds of previous posts on this subject - it's probably the shock sensor. Try disconnecting it and see if the problem goes away. If so, then you could try adjusting the sensitivity but chances are you'll have to replace it or leave it disconnected.
Old Jan 24, 2008 | 03:27 PM
letsrun97z's Avatar
so they go out for no reason it was just working and i have it set on the lowest
Old Jan 24, 2008 | 03:31 PM
Actually, they sometimes fail when there seems to be no cause but usually the failure is caused by moisture getting in the shock sensor. Sometimes it's so bad you can pour rain water out of it and other times it will appear dry until you open it up and see the corrosion.
Old Jan 24, 2008 | 04:09 PM
letsrun97z's Avatar
sure enough it had some water in the bottom of it. it was raining all day yesterday and some last night i dont know how it got in there i brushed the corrosin off and blowdryed it hopefully that works.. Thank you very much Sir
Old Jan 26, 2008 | 01:06 AM
CuriousGeorgeZ28's Avatar
I've got a similiar problem....My alarm goes off when i press the lock on the remote, after 5 seconds, every time, it goes off, i hit lock again, and it stops...
any ideas????
Old Jan 26, 2008 | 01:12 AM
z28berryhill's Avatar
this was happening to me....i changed the battery in the remote and it stopped
Old Jan 26, 2008 | 10:35 AM
i'll look into that....after digging deeper i see that everybody's unplugging there sensor and its filled with water, so i'll try that first, then the remote.
Why don't people just put some kind of plastic saran wrap around their sensor's if they all seem to be getting water?? Just seems logical, i know i'll do that...
