DIY Box Build
Old Feb 22, 2008 | 09:31 PM
cws T/A's Avatar
Old Feb 22, 2008 | 09:58 PM
cws T/A's Avatar
Old Feb 22, 2008 | 10:34 PM
cws T/A's Avatar
Set the gains with a DMM , videos arent that great of quality so bear with me . Distortion is the cameras mic being overpowered . Bass is so clean and hits crazy lows . Really satisfied with this build , alot has to do with that Fi sub , amazingly clean spl sub .
Almost 3/4 volume , car sealed up . Next step is sound deadener in the rear lol .
Low volume
Hits better with the car running , sub is still tight , cant wait to hear it when the suspension loosens .
Old Feb 23, 2008 | 12:51 AM
fredmr39's Avatar
Turned out nice - pointless vids tho.... will never even begin to do the setup justice.
Old Feb 23, 2008 | 10:18 AM
pentavolvo's Avatar
so i see u have one crossover mounted on the amp rack, wheres the other
Old Feb 23, 2008 | 03:51 PM
fredmr39's Avatar
That's for his sails, I believe... 4 in, 4 out
Old Feb 23, 2008 | 04:06 PM
cws T/A's Avatar
The one on the amp board works both midbass . Only highs in the car is the RE components in the doors ,there crossovers are in the kick panels . With the sub turned off , it still sounds great .
When I was pulling out the factory speakers , the original owner of the car must have removed one of the midbass speaker . Other was blown .
Old Feb 23, 2008 | 04:15 PM
whytryz28's Avatar
my computer subwoofer went crazy when i played your vids lol
Old Feb 23, 2008 | 04:29 PM
cws T/A's Avatar
To hear it better without the computers woofer blowing out use some headphones pressed against your ears , I found it to sound similar to the real deal this way . Still the camera mic is being taxed when ever the volume comes up .
Old Feb 23, 2008 | 05:41 PM
cws T/A's Avatar
Well I need to get an higher amp alternator asap , finish the big 3 . Voltage is dropping pretty bad when its full tilt { 3/4 volume }.
Made some more videos , just waiting for them to upload .
Old Feb 23, 2008 | 09:10 PM
cws T/A's Avatar
Turn your bass DOWN before playing videos .
{That whistling noise you hear when I start the car is the floater plate/ Textralia exo - skel dual disk . Only makes that noise when the clutch is pressed in .}
Serious Camera overload .. song is not skipping .
Old Feb 23, 2008 | 10:49 PM
  #32
2MuchRiceMakesMeSick's Avatar
Nice setup but I would probably relocate this ground...but then again, im **** about grounds
