Blowing Fuse #7 Power Accy?
I need some advise, help etc... MY Camaro SS is blowing out fuse #7 everytime I close driver's side door. With engine running or not.
Thanks,
David
Thanks,
David
The switch is before the lightbulb so power going through it (when switch is closed) is going throught the bulb then to ground. If the switch, when its open, is grounding then there will be no resistance and you will ground to the chassis and blow fuses. I say remove the switch and examine it.
Ungrounded Moderator
If you have power windows and locks, the wires go through the rubber boot between the chassis and the door, I would check to see if any are being pinched or chafed. The fuse block is also on that end of the dash facing the door. Maybe shutting the door causes enough movement in that area for a bare or chafed wire to touch and blow the fuse. I think I have the diagram for the circuit that is blowing. I will search through my Factory service manual DVD, and see if I can find it.
The only circuit in the door that is related to the PWR ACCY fuse is the power mirror switch. I would look there first although seawolf18 has a very good point about the fuse panel being close enough to the door that closing it could cause a damaged wire near the fuse panel to short out.
The other circuits on that fuse are the hatch release, the alarm shock sensor, the radio memory, and the instrument cluster.
Thanks for the replys, advice etc.... I believe I have the problem narrowed down to the alarm. The fuse pannel was loose so I re-attached that solved the problem temporarly. When I use my remotes to lock doors & arm the alarm the fuse blows. As long as I use the door key to un-lock & lock the driver's door the fuse does not blow. I guess I should try passenger side door.
David
David
