I need help?????
Old Feb 20, 2008 | 10:14 PM
Prerun4fun13's Avatar
Exclamation I need help?????
Ok so my stereo i have a pioneer deck and i have no clue what kind of speakers they were in the car when i bought it. So ill be driving along and if i hit a bump sometimes the right side door speaker shuts off then sometimes comes on again. I dont know if maybe its a loose wire or what. Also sometimes the stereo its self will just shut off while i am driving. Anyone know were i should look?
Old Feb 21, 2008 | 08:53 AM
TTT 9 views and no help
Old Feb 21, 2008 | 10:04 AM
WhiteBird00's Avatar
Ungrounded Moderator
I'm sure everyone who viewed this thread was thinking the same thing...pull the right door panel off and check for loose or damaged connections. Then pull the head unit and look for loose or damaged connections there. We can offer advice but at some point you have to start testing things.
Old Feb 21, 2008 | 10:32 AM
pentavolvo's Avatar
odds are loose connection in the door or behind radio
Old Feb 21, 2008 | 01:33 PM
Ok thats what i figured but its raining out right now so i figured i would see if anyone could point me in the right direction. Thanks for the input ill see what i can find.....
Old Feb 21, 2008 | 01:37 PM
pentavolvo's Avatar
im sayin its prly in the door, but check behind the deck first since its easier
Old Feb 21, 2008 | 04:49 PM
fredmr39's Avatar
I wonder if the two issues are related or not...
Seems odd that sometimes your entire stereo shuts off, while other times it's just the right door speaker.
Usually people who have problems with the stereo shutting off entirely had bad or loose BCM connections. How long does the stereo stay off for when it's shut off? What about the speaker? Next time the stereo shuts off (if it doesn't just flash on and off) try using your power windows, see if they work (bad BCM power/ground connection would also effect your power windows at the same time and this is a fairly common problem).
Old Feb 21, 2008 | 08:25 PM
The stereo shuts off and then turns back on right away, then the right speaker it just depends sometimes it will stay off for a while.....
Old Feb 22, 2008 | 12:21 AM
pentavolvo's Avatar
maybe multiple loose wires behind HU
Old Feb 22, 2008 | 08:52 AM
I agree. The fact that it's an aftermarket HU makes me think that there may be a problem with a couple of the wire splices behind the HU. At least it's a good place to start looking.
