amp wire ?
Old Mar 1, 2008 | 06:40 PM
SSMikeLS1's Avatar
Default amp wire ?
can you use regular house wire for the amp feed and ground,I have some 4 awg just a house grade, only a 400w amp. thanks guys.
Old Mar 1, 2008 | 06:43 PM
dragonrage's Avatar
Wire is wire. If it's jacketed and flexible enough for you, then it can be used.
Old Mar 1, 2008 | 06:44 PM
jebcamaro's Avatar
Is it solid core wire or stranded wire? If it`s stranded wire, then your fine
Old Mar 1, 2008 | 06:54 PM
SSMikeLS1's Avatar
yea, its stranded, I thought it wouldnt matter but im a electrician not a car stereo person, anyways thanks for the info guys.
Old Mar 1, 2008 | 07:07 PM
dragonrage's Avatar
solid wire would be fine... if you could manage to bend it where you need it to go. And screw-down connectors probably wouldn't work as well on it.
