My progress so far.
Old Mar 5, 2008 | 09:28 PM
NBM-LS1's Avatar
Default My progress so far. *UPDATE* more pics!
So I am making it so stealthy that you wont even know there is a system there.
Yes I know its not much but it gets the job done.
Also is it critical to get the reccomended volume in the box. Right now its a bit over half of the reccomendation.
Also hid my amp in a nice spot. You guys think I will need to mount a cooling fan for it?
So I added on to the box and got some more air space out of it. Has more than what my last box had that I made so it should be good. Still not finished but I am betting there.
Old Mar 5, 2008 | 09:33 PM
xXSilencerXx's Avatar
Awsome dude. Same exact spot my buddy put his amp.
Old Mar 5, 2008 | 09:35 PM
NBM-LS1's Avatar
Is it going to distort the sound for not having the full reccomended volume?
Old Mar 5, 2008 | 09:36 PM
chromeplated500's Avatar
wow... i like the box.. looks like you put some good time into that.
Old Mar 5, 2008 | 09:51 PM
NBM-LS1's Avatar
Still not finished either. I started a 2 today and ended about 7. I am still making it because I need to get a bit more volume out of it. Ill post up more when I am finished totally.
Old Mar 5, 2008 | 09:55 PM
Dave 96TA's Avatar
Don't forget to paint those screw heads too. Good work.
Old Mar 5, 2008 | 10:03 PM
pentavolvo's Avatar
ive done an amp there before also works out great and if u leave enough slack in the wiring u can rest the panel on the rear hump and pull the spare out and not have to unhook anything
Old Mar 6, 2008 | 07:31 AM
NBM-LS1's Avatar
can anybody answer my questions?
Old Mar 6, 2008 | 08:34 AM
KEE AUDIO's Avatar
What sub are you using? I think you could have recessed it in a bit less and gained more airspace volume but it depends on the sub as to how it will perform. It is always recommended to have at least the minimum airspace volume for optimal performance.
Old Mar 6, 2008 | 09:35 AM
pentavolvo's Avatar
as far as cooling you could add a fan but honestly IMO it will be fine
as far as only being half the recommened box size plan on it not sounding the bets
Old Mar 6, 2008 | 03:30 PM
CruzinCobalt's Avatar
pretty clean, i like it
Old Mar 6, 2008 | 03:48 PM
Breathtaker's Avatar
Very nice job, I like it.
Old Mar 6, 2008 | 04:15 PM
go-t's Avatar
Looks good and the t top holders a still functional!! Any pics of the box in place?
Old Mar 6, 2008 | 05:10 PM
NBM-LS1's Avatar
Updated.
Old Mar 6, 2008 | 08:06 PM
bmnicolosi's Avatar
How much air space were you able to squeeze out?
Old Mar 6, 2008 | 10:18 PM
NBM-LS1's Avatar
I got about .3 cubic ft. now.
