ground causing starting problems
Old Mar 9, 2008 | 09:56 PM
95hitam6's Avatar
Default ground causing starting problems
ever since i got the car it started fine, then i blew the right side speakers, then out of nowhere the headunit stop working, it doesn't come on at all, but the weird thing is when you turn the car off the deck beeps and the face moves, so its still getting power. well after all that happened now the car starts when it wants to. everything a come on but it just clicks, when it does crank it starts right up, could there be ground in the headunit throwing everything off?
Old Mar 10, 2008 | 08:13 AM
WhiteBird00's Avatar
Ungrounded Moderator
Sorry, I don't mean to laugh but... NO, the head unit ground is not affecting your car starting.
The head unit problem is probably just a fuse. There are two separate power connections to the radio - one is ignition controlled power and the other is constant (battery) power. The ignition controlled power is the one that turns the radio on and off and provides power during normal operation. The constant power is what maintains the memory and clock. It also handles things like disc eject and face movement so that they can be done with the ignition off. The ignition controlled power comes from the RADIO fuse and the constant power comes from the PWR ACCY fuse.
Your starting symptoms sound very much like a bad battery. It might be a good idea to get it tested at a local auto parts store - they usually test for free.
