Windows down with factory remote 2nd unlock button press
Still unusual that yesterday the 452t was putting out a constant 12+ on both blue/green wires, just on the meter and not yet into the BCM. Maybe my 452t, maybe I should cut it out and test it on the bench
I'll go take a look at it again now
One thing of note ... when I would put it into park and it unlocks, the door lock button is no longer functional, ie you can't get out and hit the lock button. This is normally okay since I usually lock it from the remote anyway.
You'd think once the car is off the 452t/relays are disabled and not affecting the BCM anymore so it would work as if they weren't there. I moved the power source from a switched to a constant source, and the button works when the car is off - however the doors lock themselves when you turn the car off.
I'm happy with it as it is, but if you have any insight into keeping the door lock buttons active when the power is off I'd appreciate it.
However, there seems to be some kind of weird conflict with the 452t/auto-locking.
All is fine, but if I turn off the car with the door open, the window rolls down.
Right now I'm not using a relay on the 530t ... I took it off to see if it would help, though it shouldn't being doing anything when the car is off
I unhooked power to the 452t and it's relay, and that fixed the above issue, whoever then the window loses it's "express" mode EDIT: I think I just need to adjust the sensitivity - it does occasionally use express mode
Some of the colors for the passenger side are wrong ... the motor wires are blue and brown like the driver's door -- though that should be obvious since the motor only has two wires.
The passenger switch wires aren't tan/light blue - instead it's dark blue for motor up (brown/black to 530t) and brown for motor down (white/black to 530t). There are two brown wires, I found the right one with a meter - I can double check the right one.
Should also note that the passenger switch and motor wires need to run over into the passenger door.
To get the second channel, I used this thread:
https://ls1tech.com/forums/wiring-stereo-electronics/615947-idea-progressive-doorlock-bypass.html
I used the last post with the alternative wiring since I have a 98 - it worked fine for me
It's the Peripheral Electronics PTR7 "Universal Timer/Trigger Module". It has 16 different modes to do many functions, and is programmable ... goes for about $25 shipped on eBay
http://peripheralelectronics.com/pro...?ProductID=269
Here is the mode I think I need:
"#14: Connect the GREEN or BROWN wire to a pulsed output source. Connect the BLUE or WHITE wire to a device being controlled. Upon seeing a user programmable number of pulses within a user programmable number of seconds, the BLUE and WHITE outputs will pulse once. Example, if you programmed the PTR7 to see 4 pulses within 7 seconds, then for every 4 pulses the PTR7 sees within 7 seconds, the outputs will pulse once."
So you would hook up the BROWN wire (- trigger) on the PTR7 to 2nd channel wire created by the progressive door lock mod. Then you would hook the WHITE or ORANGE (- 150ma out) to the RED/WHITE trigger on the 530t. Then you would program the box to watch for 2 pulses within 4-5 seconds.
The end result would be that the windows only roll down if you hit the unlock button twice within 5 seconds. This you would typically only do from the remote when you want to roll down the windows -- though it would still be possible to do from the power door buttons in the doors, it's pretty unlikely someone would hit their unlock button twice in a row. You can tap the door unlock button and it would just unlock the door now, and no longer roll down the windows.
Hopefully this will also filter out the phantom pulse coming in somewhere with the shifter auto-locking mod in certain circumstances.
What do you guys think... does this sound logical?
I got a suggestion to use a RAP ... retained accessory power ... source for the relay on the 530t. This would allow you to still use the the locks when the car is off, until the doors are opened. I tapped into the pink wire on the factory stereo harness.
However I'm still having the problem ... even when the relay is being powered by a simple switched source (or when I open the door from a RAP source) the windows automatically roll down when power is lost. I can't figure out why ... I'm going into the red/white 530t wire (- auxiliary input) between 87a and 30, and than 85 GND, 86 switched/RAP 12v.
I did cut the wires on the 452t out to the door locks to make sure that wasn't somehow affecting it
Any suggestions?
I just got the schematics for the 530T so I'll have a look at them (and the how-to thread) to see if I can find what's causing the interaction with the locks.
