My custom x50 hardwire
Old Apr 23, 2008 | 02:20 AM
jdroelle001's Avatar
Default My custom x50 hardwire
I’ve had my Escort passport x50 in my car now for about a year and a half, mounted high above the rear view mirror, but just finally got around to hardwiring it. Since I wanted to make this look very nice and unnoticeable in my car, I put a little extra work into it.
I went to best buy, and bought the hardwire kit for my radar detector. What you get is the main unit, that has a mute button, power indicator, and alert indicator, and the wiring that is needed to hook it all up (power, ground, and detector wire).
Hardwire kit:
I took the main unit apart, putting the sticker off to the side. Then I pulled the interior panel out of my car where I wanted to install the hardwire kit. I drilled 3 holes to match the 2 led’s and mute button into the interior panel. Then I had to sand down the face of the hardwire main unit so that everything would show nicely, and the mute button was usable. I then lined up the main unit behind the 3 holes I drilled, and epoxy’d it all around to hold it in place. Wired it up, and put everything back together. The last thing I did was put the sticker of the hardwire kit back over the 3 holes I drilled.
I have it wired to a source that only gets power when the car is on, but I also added a switch to it so I could turn it off if I wanted. You can see that in the following pictures as well.
This is the final product. I know a lot of people have done this, and I think it looks great. Sorry I didn’t take any “in progress” pics, but if you have any questions just ask, it really wasn’t too difficult.
And the x50 located above the rear view mirror, just below the tint strip
Old Apr 23, 2008 | 08:38 AM
Mikzgp's Avatar
That is kick ***. I like it. I am not that good at that kind of thing I just velcro'd the remote mute botton on the panel under the steering wheel. Why would you add a switch to turn if off instead of the factory on/off switch?
Old Apr 23, 2008 | 09:09 AM
dragonrage's Avatar
I don't like the positioning of the remote stuff.
Old Apr 23, 2008 | 11:21 AM
Well, if I get pulled over, I want to be able to turn it off, without the officer seeing me reach up to do it. I know their legal in my state as they are in most, but if the cop knows you have one, chances are you won't be getting off with a warning. They'll just write you whatever ticket they pulled you over for.
Whats wrong with the positioning? I wanted to have it mounted more in my clear line of site, but I don't have any problem paying attention to the detector. I really just need the mute button there. The original power cord that came with the detector was always plugged into that cig lighter, and I got used to it being in that area. I guess I'm just used to it. Care to elaborate on [I]why[I] you don't like it there?
Old Apr 23, 2008 | 11:24 AM
dragonrage's Avatar
Because I wouldn't like ever having to turn my head that far down.
Old Apr 23, 2008 | 11:32 AM
Yea, I guess like I said I just got used to it because thats where the old power cord was plugged in. Now I love it there. I was trying to find other places to put it, but it wouldn't have looked nearly as good. I like to just reach down and press the mute button whenever I get a false. I don't even have to look to hit it. Really I only look at the detector itself. The hardwire kit only shows if your getting an alert, not what radar band it is or how many signals.
Old Apr 23, 2008 | 06:30 PM
WhiteBird00's Avatar
Ungrounded Moderator
I agree. I have my remote mounted in a similar way and don't have any problem with it. It's almost never necessary to look at it since the audible alert tells me what type and how strong a signal I'm picking up. Passengers find it interesting though.
Old Apr 23, 2008 | 10:57 PM
Keith Lewis's Avatar
Just another piece of info. It is better to have a radar detector mounted low on the windshield to pick up radar bands. It is better to have a laser detector mounted high in the windshield to pick up laser bands. Probably more than 90% of the time you get hit with radar. So I would recommend moving the radar detector toward the bottom of the windshield. You did spend a lot of money on that radar detector, why put it somewhere that doesn't pick up a good signal?
Old Apr 24, 2008 | 12:29 AM
you're actually 100% wrong... Laser is line of site, so if you have it lower (the cops aim for the front plate, headlights, etc) it will have a better chance of picking it up. Radar, which is a broader range, will be detected earlier higher. If you still disagree, check out radardetector.net and do some research. Not trying to be an ***, I just hate all of the false information out there about detectors.
