Help me complete my set up.
Just to confirm, I will be running the Power Cable from the Batter to the Amp from the passenger side and the rest of the cables from the driver side correct?
I know the Blue Wire in the Amp Kit connects to my battery but how do I apply the Monster 300 MIDI In-Line Fuse Holder to the cord?
Do you have any friends that have done this before? It'd be good to have someone to help you, just because you've never done it before.
As for the remote cable, is there a special connection on the head unit or do I splice one up?
The remote wire will connect directly to another blue wire on the harness that came with your deck. It might even be labeled as "remote" or something. If it's not labeled and you want to be sure, just take a look in the manual that came wit your HU. There should be a wiring diagram in it somewhere.
Can you please explain how I connect the GM Antenna Adapter? I've never seen one in person but from the picture it looks long. I think this is the only thing left that I'm clueless about. You have been a great teacher hatch.
