Turn Signal Flasher
All bulbs work.I've check by blinking my hazards and they blink and work as they normally should,and my parking lamps/courtesy lights work good as well.The side of the car to which i'm signaling stays solid and does not blink.Happens to both sides and there does not appear to be any burned out bulbs.
So from here everything points to the turn signal flasher in my dash being the culprit.I have an idea on where to find it,but I wanted to ask if this is a pretty straight forward job...Will I have to solder anything or is the flasher pretty much just unplug old and plug the new one in? Is there a certain type of flasher that I'd need to buy (other then telling the parts guy the year/model of my car...like voltage,amperage,prongs or something?)
New to electricals so just wanted to make sure before I replace it.And if anyone knows of a write up,please share.Thanks.
Thanks.
As I said before the hazards were working fine and all the bulbs that should blink,blink fine with the hazards switched on.No burned out bulbs or irregular blinking either.The turn signal flasher that was acting up originally was also electronic.Maybe the previous owner had some work done to it.He wasn't into modding the car at all though.
The electronic one I put in seems to work great so far...blinks faster than the electronic one I replaced before it went out, but not irregularly fast like you see sometimes on some ricers.
I'm just wondering if I'll have to replace the socket or hopefully just a flasher.
The aftermarket flashers on my wifes trans am would never work correctly, they would always be too slow, or not work at all. After messing with 5 different part store flashers I just had to swap the hazard flasher into the turn signal flasher and they finally worked normally again.
So if you have problems with an aftermarket flasher in the turn signal on a trans am, put the stock hazard flasher into the turn signal flasher slot and the aftermarket one in the hazard slot
