Replaced Stock Front w/Infinity 62.7i - Sounds Like Hell
I have been looking at cross overs. The factor speaker uses a cap for the tweeter. Not sure what is uses for the door. I have not got that far. If you put a 4ohm speeker in place a 2 ohm you will change the cross over frequcy by like half. you will need to take out the factor crossover and use the one that came with you speekers. The problem is that there is only one input to the new cross over. I am going to split the new cross over I got into to seperate inputs. One for the woofer and one for the tweeter.
Depending on which speakers you buy, some will not be too bad with the stock crossovers whereas most will be bad and some will be downright terrible. First order crossovers are almost impossible to use in a 2-way system. You need a tweeter that plays down to say 1kHz (which means a 1.25" or so tweeter), a woofer that plays past 6kHz (8 would be much better), and a crossover point of probably 4kHz. And when I use the word "play" in this case, I mean flat to. It's hard to do with a 5.25" woofer and even harder with a 6.5" or woofer.
Any decent aftermarket 2-way setup will use 2nd order if not 4th order crossovers. Non-paper speakers should definitely use 4th order.
i have kappas in the front and reference in the rear with reference amps and mine is crystal clear and LOUD. all new wiring of course through the door boots.
