is this even possible??
Old Aug 21, 2008 | 12:45 PM
dutinsss's Avatar
Default is this even possible??
ok, i have no idea if this is even possible but i had this idea and want to know if it could work. i've got an amp box that holds my amps in the hatch area. is it possible to put all the wires that go into the amp box into a plug so i can simply plug and unplug my amp box so i can easily take it out of the car when i race?
Old Aug 21, 2008 | 03:06 PM
Tuffguy610's Avatar
Sounds do-able to me. I would do something to the tune of mounting a distribution block on the actual box so that you could just undo the main power wire from it and pull the assembly out. All you would have to do then is pull out the RCA cables and the remote cable, which could have a quick disconnect of some sort since it is so thin and doesn't require a lot of power
Old Aug 21, 2008 | 10:04 PM
bmnicolosi's Avatar
They make quick disconnect plugs for that. I used them before at a shop i used to work for.
Old Aug 21, 2008 | 10:13 PM
pentavolvo's Avatar
100% doable ive done it before
Old Aug 22, 2008 | 06:42 PM
dutinsss's Avatar
ah tight. so you can combine all the wires that go in and out of the amp box into one quick disconnect fitting? anybody have any pictures of theirs?
Old Aug 23, 2008 | 03:18 PM
pentavolvo's Avatar
2 seperate plugs you will need seperate one for power, then do a molex type setup for the rcas and remote wire is waht ive done
http://www.partsexpress.com/webpage....up_ID=187&SO=2
http://www.partsexpress.com/pe/showd...number=092-560
Old Aug 24, 2008 | 10:02 AM
dutinsss's Avatar
ok, one of the amps is powering 4 door speakers and the other is powering a 10. your saying i could do this with just the 3 items in the links? i dont know jack about wiring so pictures would help greatly. thanks for the info.
Old Aug 29, 2008 | 12:51 PM
dutinsss's Avatar
bump. i'm looking for a way to combine all the wires into like 2 or 3 plugs. i dont want to have to connect a million different wires everytime i take it out.
Old Aug 29, 2008 | 01:40 PM
pentavolvo's Avatar
let me come up with something in a bit its doable though with some work... if i dont post back in the next few hrs pm me reminding me to lol
hows are ur amps set up do u have distro blocks or what
detailed wiring layout would help
Old Aug 29, 2008 | 01:51 PM
blackbyrd's Avatar
i dont know a whole lot about stereo stuff but i dont know if you get your power wire to close to the rca's on occasion you get feed back through your speakers, so you might want to keep your power wires separate from the rest of it, just a suggestion
Old Aug 29, 2008 | 02:43 PM
dutinsss's Avatar
i didn't wire it and i dont know much at all about wiring but i don't think it's anything too fancy. i have my 4 door speakers on a 2 channel hifonics amp and the 10'' sub is on the 800 watt powerbass. it looks like all the wires are seperate so i don't think i have a distro block or anything like that.
and good info blackbyrd. i think your right about some wires cannot touch certain other wires.
