new sails no bass
Old Aug 24, 2008 | 02:36 PM
RealLiveMD's Avatar
Default new sails no bass
I replaced my factory blown sails with the bazooka sails. My system lacks bass. If I try to turn the bass up. The speakers sound distorted. Honestly, my sails have been out over a year and I haven't been playing any bass. Now though the system sounds crappy. Far inferior to original. Any suggestions? I've read good things about these speakers.
Old Aug 24, 2008 | 09:30 PM
01 Red WS6's Avatar
I just finished installing mine today and it's much better than the factory speakers were. I too have been without bass since my driver side went out completely about a month ago and I was suprised how much better these were. Maybe you were expecting a lot more out of the speakers? If your not happy with the amount of bass add a stealth box and a 10" sub that should fix it
Old Aug 25, 2008 | 02:17 PM
RealLiveMD's Avatar
naw, there is definitely something wrong with mine. It may not be the speakers. It may be the unit or amp. It seems as if the speakers aren't really receiving proper bass tones.
Old Aug 25, 2008 | 09:36 PM
01 Red WS6's Avatar
are you on the factory HU?
Old Aug 25, 2008 | 11:29 PM
JoeKnowsBaseball's Avatar
If you have the factory amplified system, bypass it all through an aftermarket head unit and run your own speaker wires. The sound will drastically change.
If you don't have the amplified system, try getting a new stereo. Or you're just expecting too much bass out of a 5.5" speaker. IMO the less bass in a speaker that size, the better. The higher end speakers of that size won't have bass. Cheaper the speaker, more the bass.
Old Aug 26, 2008 | 11:08 AM
murzyn123's Avatar
double check all ur wires maybe you hooked up - to + by accident that will make a crappy sound
Old Aug 26, 2008 | 12:56 PM
RealLiveMD's Avatar
I'll have to check.
Also, it's still the factory monsoon system.
I'm not expecting more than I had stock, but this is horrible. I guess it's time to upgrade. Anyone know which radio allows one to put that firebird center on as the screensaver? I've seen that posted on a few cars.
Old Aug 26, 2008 | 01:57 PM
Dragwheelz.com's Avatar
You probably have a wire crossed and what you are experiencing is whats called out of phase.
Old Aug 27, 2008 | 08:32 AM
stevez2885's Avatar
or just buy some real speakers (bazooka is garbage)
Old Aug 27, 2008 | 11:58 AM
RealLiveMD's Avatar
Does it matter which side of the speakers are hooked to what. I know that positive and negative matter; but, I'm referring to the dual voice coils.
Old Aug 27, 2008 | 01:27 PM
with the dual voice coils you have 2 options.
series or parallel.
series is 1+ side of 1 voice coil to the - of the other voice coil. and you wire up your + and - to the open terminals.
paralell is when the positives and negatives are wired together.
Old Aug 28, 2008 | 01:13 PM
WhiteBird00's Avatar
Ungrounded Moderator
In this case, series or parallel isn't an issue since the factory Monsoon wiring runs each of the voice coils on separate channels from the amp. Just make sure you haven't mixed the pairs across different voice coils and that you don't have the phase (positive vs. negative) reversed on one coil from the other.
