WHOA... what is this blasphamy
Replacing the lever is very simple. There is a small trim panel (about 1" x 2") on the side of the plastic steering column housing that just slides off. Once you remove that little panel, you can remove the one screw that holds the lever in place. Then all you have to do is pull the lever out and disconnect the wiring connector. Installation is the reverse - insert the new lever, plug in the wiring harness, insert the retaining screw, and replace the trim panel.
On a side note, if your wipers are still stuck in the middle of the windshield, try using the washer switch. It is a separate switch (electrically) and might still work to park the wipers even if the main wiper switch is defective.
