H/C - 10.89 @ 124mph (Pics and Vids)
Went to a track rental last Monday and managed to sneak into the 10's on a few passes...previous best was 11.48 @121 on 17" radials.
Details:
TEA 243 stg 2 heads ~11.4:1 cr
228/232 111lsa streetsweeper HT cam
VR ported Fast 102
All supporting bolt-ons and suspension
stock 4l60e, vigilante 4k stall, S60 w/3.73 gears
My car made 457rwhp 420rwtq, race weight is 3380lbs with me in it.
11.050 @ 123.95
10.956 @ 124.24
11.267 @ 122.51
10.968 @ 123.91
10.963 @ 124.08
10.891 @ 124.24
10.930 @ 124.24
10.939 @ 123.89
10.89 @ 124.24mph
Details:
VR ported Fast 102
11.050 @ 123.95
10.956 @ 124.24
11.267 @ 122.51
10.968 @ 123.91
10.963 @ 124.08
10.891 @ 124.24
10.930 @ 124.24
10.939 @ 123.89
10.89 @ 124.24mph
Great run, congrats!
What changed from your previous best 11.48 run? Just the wheels or cooler air also? I'm currently runing around an 11.1@120 and trying to justify buying drag wheels. Thanks
I ran the 10.89 @ 124 the following week with the only change being the drag wheels/tires. They are 15x3 bias fronts and 15x8 QTP's in the rear, which dropped just over 100lb rotating mass. I could hammer down right off the line with this combo and for the most part it would dead hook. Basically dropped almost .5 sec and gained 3mph with them, so I would say they are worth it.
I removed everything I could without compromising the interior too much. !abs, !airbags, no front support, race carpet, aftermarket seats, no emissions, no washer tank, etc. All tubular suspension up front, and the hood is light. I still have all the interior panels but the door panels are aluminum that I covered in black vinyl. For the amount of stuff I pulled out I expected the car to be much lighter but some suspension parts, roll bar, and the s60 add a bit.
Since then I swapped out the ls6 intake for a VR ported FAST 102, and got re-tuned. Realistically I picked up about 25 peak and 10-15 across the rpm range from my old numbers. Not bad considering the new numbers were through an S60 and 4" DS, while the old dyno pull was through the stock 10 bolt and DS.
