11 Second Club Snake eyes are a good thing
well im in the 11s with the AFR 205s
Old 04-23-2012, 07:25 PM
edub80's Avatar
Angry well im in the 11s with the AFR 205s
well i went to the track saturday... the car disapointed me..here are the results
60ft 1.77
1/8th 7.65 91.74mph
1/4 11.90 116.88mph
Untuned except for the injectors
01 z28 A4
afr 205s
fast 92/90
pat g cam
30# svo injectors
3.73s
3200 converter
26x10.5 mt dot slicks
was expecting atleast a 11.5 11.6
im gona get it on a dyno sometime in june
Old 04-23-2012, 09:06 PM
Its Slo's Avatar
Converter is killing it but it should pick up with a good tune.
Old 04-23-2012, 09:30 PM
edub80's Avatar
Well I ran 12.2 with stock heads cam and ls6 intake... so i gained 3 tenths from H/C/I... just thought I would pick up more than that even untuned
Old 04-24-2012, 12:16 AM
StreetSilverado's Avatar
Put a real converter in it or spray the hell out of it...and get a tune.
Old 04-24-2012, 09:01 AM
thunderstruck507's Avatar
Wow. What does the car weigh?
You're running around the same times as me in my tank. Get a tune man surely it will wake up some but if it's not really bad off I would be worried. What was the DA, maybe it was bad?
Old 04-24-2012, 09:20 AM
Captain Double Post
BOBS99SS's Avatar
so your running with no tune whatsoever???? not smart if ya are,and that convert, blows, you have a killer setup but there are 2 things that stand out to me why its not running that well
Old 04-24-2012, 06:48 PM
edub80's Avatar
the car has no weight reduction so im guessing its around 3850 with me in it...the da was around 650 at the time of that run... also it will be tuned by june
Old 04-24-2012, 06:56 PM
edub80's Avatar
no it has a street tune on it and tuned for the injectors...i know the converter is not great for my setup but it should be ok till i have to replace the stock tranny.. also whats crazy is i pulled a 1.73 60ft with stock H/C/I... and i pull a1.77 60ft with the new setup... so im thinking a dyno tune will get it running better and if it dont then something is not right with the motor, which i hope not
Old 04-24-2012, 08:40 PM
Mac 2002 SS's Avatar
I agree with the rest of the guys. Find a good tuner and make plans to upgrade that converter to a 3600-4000 stall ,then hold on !!
Old 04-24-2012, 09:01 PM
edub80's Avatar
Well what should I expect out of it being tuned with the 3200 stall? And then say a 4000 stall?
Old 04-24-2012, 09:36 PM
Z28SteveA4's Avatar
she really needs to be tuned. Your mph for a head cam car should be in the 120-125mph range. You mph is a cam only mph so she deff needs some tuning help. If you stepped up to a 4000 stall the way you sit you will probably be in the 1.5 60' range and the way you sit with a 1.5 60' should drop you right to an 11.6 pass. then get her tuned and drop into the lower 11's. Dont be dissappointed with her until everything is worked out.
Old 04-24-2012, 09:38 PM
Z28SteveA4's Avatar
let me state that you can't just put a 4000 stall in the way she sits either. She will need to have the shift points changed other wise you will be bagging off the rev limiter every shift. so put the a bigger stall in and get her tuned lol
Old 04-25-2012, 11:41 AM
The 3200 stall won't keep your cam in it's powerband like a 4000 stall would. With a 4000, you should be in the 11.6-11.3 et area at 116-121mph at most. Once it is re-tuned with a new 4000 stall and shift points adjusted to at least 6600 or 6700rpms, you will see and feel a big difference.
Old 04-28-2012, 12:25 PM
garygnu's Avatar
what suspension modes do you have ?looks like a great combo.
Old 04-28-2012, 04:53 PM
Cajun99SS's Avatar
4000 stall would definitely help.
Old 04-28-2012, 07:52 PM
s346k's Avatar
car needs a tune. a friend of mine picked up 7 mph from a tune with his cam only a4 car. the car had a driveability tune on it beforehand, but no wot tuning.
as said before, get at least 4k (i'd go 4400) stall and real tune on the car, it will pick up huge.
Old 04-28-2012, 08:36 PM
edub80's Avatar
it has the stock suspension on the car... the front sway bar has been removed though
yeah i know it needs a min of 4000 stall but im not gona replace mine till the trans goes out
yea it really does need WOT tuning... i hope i can pick up a good bit like your friend did... also i think a 4400 stall woud be a lil much imo... i really think a 4k would be plenty... you just dont see many cars that are street driven with a 4400 or bigger converter.....but its no where near considered a daily driver lol... ive put maybe 500 miles on it this year... and about 8k on it last year
Old 04-29-2012, 12:51 AM
garygnu's Avatar
I feel you need bigger injectors and a bigger fuel pump.
Old 04-29-2012, 05:53 PM
edub80's Avatar
well when i get it on the dyno i will see what the duty cycle is and then go from there.. but the 30# svo injectors in it should be enough but it might not be
Old 04-29-2012, 06:48 PM
01 blue bullitt's Avatar
I am in a similar situation, my car has prc 2.5 5.3 heads, torquer v2, 1 7/8" long tubes, stock gears, fast 92/92, and 3800 stall. I expected 11.5 I had similar da to you as well but car ran 11.75 at 116. I think the mph on both of our cars is low. I too need a tune. When I got the car it had heads and cam but the tune was fair at best. It also had Mac midlengths and 2 1/4" exhaust. I took the exhaust off put the long tubes on and put a fast 92/92 in place of the ls6. I have to retune retune the car.
Quick Reply: well im in the 11s with the AFR 205s
