11 Second Club Snake eyes are a good thing
New Best from Grudge Wars!!
Old 04-24-2005, 06:34 PM
mikes02ls1's Avatar
Default New Best from Grudge Wars!!
R/T... .015
60'... 1.822
330... 5.063
1/8... 7.716
MPH... 93.09
1000... 9.976
1/4... 11.868
MPH... 120.39
Well I couldn't hook for **** on my worn out 255/50/15 BFG DR, spun to a shitty 1.8 60ft. Also was leaving at 3,000rpms.
It was a good time glad to meet the south side crew bond motorsports. Street Lethal did a good job! Track officials could have done better like more water in the water box and prepping the track. Still had a blast.
I GUESS I'M STILL ONE STEP BEHIND THACKER HUH?
Where was Thacker? I was waiting for my race, well lets see what excuse he has now...
Mike
Old 04-24-2005, 07:32 PM
12stones's Avatar
Soild times mike, i'd get some mickey t radials. they dropped my 12 flat on nittos to a 11.6.
Old 04-24-2005, 07:52 PM
mikes02ls1's Avatar
i had some but couldn't get them to fit, damn I need spacers or a different offset. The wheels are my friend Diet Coke
Mike
Old 04-28-2005, 02:32 PM
Vortec5300's Avatar
Damn I need whatever you've got! I have a similar combo and run a second slower and about 7 mph. I think I needs those 4:10s to get mine to work right. My 60' was only 2 tenths off but my 330' was .5 tenths off yours so..gotta be the gearing.
Nice run and excellent mph! That speed shifting also? what were you shifting at with the MS3?
Old 04-28-2005, 06:39 PM
mikes02ls1's Avatar
No speed shifting don't want to rebuild my tranny again.lol My rev limiter is 6,700. Thank you. What mods do u have to your car?
Old 05-01-2005, 05:08 PM
Vortec5300's Avatar
My car has Pace LTs, OR-Y pipe, LS6 intake, Magic Stick, Borla, lid, free mods, makes 403hp, 380lbs tq. I ran it a few weeks ago and it only went 12.70s@113 and we have been trying to figure out why. The race weight was 3720#s, running on nittos and hooking up getting 2.0 60's but the 1/8 was only 88mph. I think gears would really help it. Seems to be pretty flat under 4500rpms so....
Old 05-01-2005, 06:05 PM
mikes02ls1's Avatar
I guess it is a A4? Nittos suck unless they are brand new.. BFG DR are better. U need some gears bad.. My race weight is 3,575 but i'm a hardtop.
Mike
Old 05-02-2005, 08:56 PM
Vortec5300's Avatar
Nah its an M6 with stock 3.42s. I think 4.10s would really help it. If you analyze my slip, you can see the weak 330' and 1/8.
60'--2.045 Dumped clutch at 3500, hooked good
330'--5.598
1/8--8.38@88.54
1/4--12.72@113.93
60'-- 2.067 Dumped clutch at 3500, hooked good
330'--5.593
1/8--8.37@88.80
1/4--12.72@113.22
60'--2.134- Came out at 3500, released clutch quickly but kinda slid it to keep the rpms at 4k, but clutch hung up and slid too far, smoking it down the track literally.
330'--5.55 NOTICE THIS!!
1/8--8.328@88.16
1/4--12.71@112.14
Eventhough the 60' was a full tenth slower, the 330' was .04 quicker which was reduced due to the rpms staying somewhat near the powerband I believe.
Old 05-02-2005, 09:05 PM
mikes02ls1's Avatar
330'--5.598
1/8--8.38@88.54
1/4--12.72@113.93
330'--5.593
1/8--8.37@88.80
1/4--12.72@113.22
1/8--8.328@88.16
1/4--12.71@112.14
Man 4.10 really wake up the car.. I hated driving around with 3.42 also was high to mid 12's with them.. 4.10 is where its at, but now i might go with 4.30 if i don't spray.
In sixth at 80mph my rpms are around 2,300 so its not that bad.
Old 05-02-2005, 09:06 PM
mikes02ls1's Avatar
Also u need some sticky tires, nittos just don't do the job.
Old 05-02-2005, 09:27 PM
Vortec5300's Avatar
My car is definetly not setup for drags but it SHOULD be going 12.20s@116. Car is lowered with Hotkis springs and sub frames, MAC LCAs, Random T/A. Also has heavy 17X9.5 centerline aztecs with 275s in front and 315 nittos in the rear. The nittos were hooking good at any dump below 3800 and WOT at the dump. Didn't get to spray it because the nitrous line blew but... It just seems to not pull that hard at all until 4500, feels slower then stock below 4500 eventhough the dyno chart is showing 300+#s tq at 3k rpms... I was shifting at 6400-6500 and was shifting relatively fast while lifting throttle. Should be going 5.0s in the 330' and atleast 90 in the 1/8 with the same setup. I think its all in the gearing. HOPEFULLY its not just weak.
Old 05-02-2005, 09:33 PM
Vortec5300's Avatar
Here is the chart from 2 months ago. Have changed nothing since this. Does it seem weak down low?
Old 05-02-2005, 09:35 PM
Vortec5300's Avatar
So your car only went mid high 12s with the magic stick/bolt ons until you got the 12b w/4.10s? Thats very interesting.
Old 05-03-2005, 06:35 AM
mikes02ls1's Avatar
Yeah I think I hit a 12.4 but 3.42 do suck for this cam. U won't believe how it feels with 4.10. I put 4.10 in my 10 bolt first and got the 12 bolt the next year.
Go get the gears then see what it will do.
Old 05-03-2005, 01:50 PM
Vortec5300's Avatar
I think with a ported TB and a pulley, and a tad more tuning I could match your 416hp, ,its the low end torque that seems to be killing me. I am thinking the 4.10s will make up for some of this but...there is no denying the .5 I am off in the 330', hell that is only 1st and into 2nd gear so there arent a lot of factors there assuming the 60' is a consistant 2.0. Car is just too flat from 1500-4500 and can't make up for it enough from 4500-6500. The nitrous will help the bog but I want it to run well on motor also.
Old 05-05-2005, 08:55 PM
mikes02ls1's Avatar
Good luck and let me know what it does.
Quick Reply: New Best from Grudge Wars!!
