12 Second Club In the 12s yet? Come inside!
What should I run now?
Old 07-01-2010, 07:53 PM
cory123456's Avatar
Default What should I run now?
I just put In a 3200 stall, before the stall best I ran was a 12.8@109 with a 1.9 60ft with the mods in my sig minus the stall, what about should I run now?
Old 07-01-2010, 07:57 PM
projectX's Avatar
Damn you ran good before. Guessing with some sticky tires 12.2
Old 07-01-2010, 08:07 PM
lemons12's Avatar
Should have went larger on the converter.. Depends on the brand/STR as well.
I would guess around 12.4 1.7 short time. You might lose some on the mph, you might gain some.. Or it might stay the same. All depends on how efficient the converter is.
Old 07-01-2010, 08:11 PM
FASTEDDIE Z's Avatar
Street tires or drag radials ?? On drag radials ,youll probably drop @ .4 tenths . On street tires , you might lose some time due to traction .
Old 07-01-2010, 09:31 PM
cory123456's Avatar
It'll be on drag radials, and I got a coan racing stall
Old 07-09-2010, 12:50 AM
Z28SteveA4's Avatar
depending on the air im going to agree with lemons12 a 12.4 with a high 1.7 60ft
Old 07-09-2010, 07:34 AM
BKDZ28's Avatar
You will be in the 12.4-12.6 range. I just installed a SS3600 in my car, been to the track once, three runs best run 12.5 108.5 with a 1.8 60ft Before the stall I had the same mods as you and also ran 12.8 at 109 2.0 60ft My best time I launched around 2000rpms. Best of Luck!
Old 07-09-2010, 08:43 AM
PewterScreaminMach's Avatar
What kind / size drag radials? Also keep in mind weather conditions this time vs weather conditions on your previous best run. If weather conditions were stellar for your previous best runs but the temp and humidity are significantly higher this time around, you may not see a very big improvement. I only mention it because people so often get pissed when it happens, not realizing how much of an impact DA can have on their times.
That said, assuming similar DA, I'd guess 12.4-12.5 if you can hook.
Old 07-12-2010, 11:57 AM
cory123456's Avatar
i got nitto dr, 245/50/16 when i ran the 12.8 it was pretty hot like 88 but with lower humidity then now. i think i may wait till winter or fall to run my car again.
Old 08-09-2010, 02:42 PM
Funkster's Avatar
Fall will usually net you the best air.
I wouldn't be able to wait though.
Old 08-09-2010, 04:36 PM
TheBlueKnight's Avatar
Eh...tell me about it. In Fallon at 4,000ft I trap 107mph, and in Sacrmento at sea level I trap 114mph!
To OP, I'd say consistent 12.4-12.5's.
Old 08-10-2010, 08:41 AM
blk/slvr02ss's Avatar
Between 12.3-12.5 depending on your 60ft.
Old 08-10-2010, 09:35 AM
TrikeMike's Avatar
I am also with lemons. I was 12.8 and put a 4000 vig in my car and so far in hot humid weather I went 12.4 with the trans smacking the rev limiter 2-3 shift. Once I get the shift points worked out and on a better night I'm thinking 12.2 for me. my 60fts are 1.66-1.67.
Old 08-10-2010, 03:39 PM
lemons12's Avatar
What is your gear selector in when it is hitting on 2-3 shift?
Old 08-13-2010, 11:31 AM
Camaro Junky's Avatar
No kiddin! 12.8 is damn good!
Old 08-22-2010, 07:54 AM
1Bad97WS-6's Avatar
I went with a 3200 stall also. Iam doing LT's/ORY when I install my Converter. My buddy went with the same convereter as me and LT's and a tune his best is a 7.90@90mph with 1.7 60ft. Thats like a 12.32 in the 1/4. I say 12.30s-12.50s..Another buddy went 12.19 cant remember the mph with a same 3200 stall I went with,
Old 08-22-2010, 08:13 AM
U need atleast a 3600 stall.Look @ my 02 SS w/ just bolt-on's 11.88 @ 133.50 and no weight reduction.
Old 08-23-2010, 02:55 AM
nmass399's Avatar
12.5 if you hook which you should. Maybe a 12.4 on a good run. Post up the results when you get the new times
Old 08-24-2010, 06:37 AM
MonmouthCtyLS7's Avatar
I definately would have went w/ atleast a 3600...but like the other guys id say around a 12.4
Old 09-07-2010, 10:05 PM
cory123456's Avatar
im hopin to go to the track here maybe this week or next depending on the weather, ill post new times when i get um.
Quick Reply: What should I run now?
