12 Second Club In the 12s yet? Come inside!
94 camaro z28 12.41 pass
Old 04-22-2012, 11:44 AM
unioncarpenter84's Avatar
Default 94 camaro z28 12.41 pass
94 camaro first track pass with 12.41 @ 109 and 1.75 sixty foot time
with heavy american racing wheels and drag radials on stock z28 wheels
pulled drivers side wheel a lil
Old 04-22-2012, 11:48 AM
WhitePhoenix99's Avatar
Nice run.. what's the setup?
Old 04-22-2012, 11:52 AM
Lt1 350 bored to a 355 UNDER 8,000 MILES ON RE BUILD
Heads ported and polished (flows: intake 278, exhaust 197)
CC Cam 230/242, .510 lift,113 lobe separation
Comp Cams Pro Magnum 1.6 roller rockers w/7/16" studs
Comp Cams 987 Dual Valve Springs
SI Silverline Series Valves,(2.00" intake and 1.97 Exhaust)
Eagle H beem connecting rods
JE Forged Nitrous Pistons
Crane Hardened Push Rods
Intake.
Ported Intake Runners to match Heads
K&N Cold Air Induction
Relocated Air Intake Temp Sensor
A/F Ratio Gauge (in piller pod)
Exhaust
Hooker Headers Long tubes.
3" Custom Made Y Pipe
Borla 3" Exhaust Sounds amazing.
Electrical
Custom Tuned Computer (Lt1 edit)
MSD RPM Activation Switch (with RPM pills)
Accell Super Coil
LT1 Scanmaster%"Tach w/ shift light (light used for NOS Activation)
NOS Automatic Bottle Opener
Fuel
FMS 30lbs. Injectors
NOS Nitrous System (Adjustable from 50-150 HP)
Powershot Nitrous, Fuel and Purge Solenoids
Bottle Heater
Bottle Warmer
New fuel pump
Transmission
Rebuilt Stock Automatic Transo Shift Kit w/ 3 washers installed UNDER 10,000 MILES ON RE BUILD
Hayden 24,000 Tranny Cooler
Tranny Temp Gauge (In Piller Pod)
PI VIG 3500 Stall Converter
Suspension
GMS lower Control Arms Relocation Brackets
GMS Rear Lower Control Arms
GMS Sub Frame Connectors (welded)
GMS Strut Tower Brace
Drive shaft loop
Rear end is out of an 02 SS that the guy told me he took out about 7,000 miles and has torsion locker with 4.10s
Brakes
Hurst Line Lock
up graded 02 rear brakes
no bottle ran took all the nitrous stuff out
Old 04-22-2012, 12:03 PM
Hmm 109mph seems REALLY low for a heads/cam car.. was the car dyno tuned?
Old 04-22-2012, 12:49 PM
tht was first solid run on the car i nvr ran it before first run i red lighted and missed second and still got 105 then second run it was 109 but then it got rained out....its got more in it
second run was tht i left it in drive and let it shift it self
whats the mph u think i should be getting??
Old 04-22-2012, 01:07 PM
If you have an auto tranny you don't want to be shifting it yourself. Just put it in D or 3rd and let it do its thing. You're only going to hurt your time shifting it manually.
Just for reference, my car with stock heads trapped 109-110. Having ported heads I would expect at LEAST 114+.
Again, did you have the car tuned on a dyno?
Old 04-22-2012, 01:08 PM
no i didnt im in southwest pa who does tht around here kno anyone?
car is shifting like 7k
Old 04-22-2012, 01:09 PM
ya its auto i dunno maybe cuz i got 410s maybe thts why im not getting a better speed
Old 04-22-2012, 01:14 PM
So is it a mail order tune, or has the car not been tuned at all?
There is quite a bit of power being left on the table with no tune
Old 04-22-2012, 01:15 PM
the guy i bought it from said he bought tuner cats the cd and cable...
and emailed back and forth and they gave him a tune to run does tht seem right??
do u kno any good ones
Old 04-22-2012, 01:19 PM
i didnt lauch the car shoulda lauched it at 2000 rpm i lauched it from idle think ill get more mph from lauching it....
but from lauching it at idle the 60 ft was still 1.75
I'm not really sure in your area who would tune it but that would be the first thing on my list to get done. The car would pick up A LOT
Check in the Eastern members section on here and ask those guys, they might be able to help you out finding a good tuner.
Old 04-22-2012, 01:22 PM
Your launch isn't affecting your mph, maybe your et. You can play around with the launch and see what the car likes and what gets the best 60'.
But again, that isn't going to have an impact on your mph.
with whats done to it wht do u think itll run with a good tune with the looks of it
Old 04-22-2012, 01:28 PM
With a good tune and some work on your launch and 60' time you should be solidly into the 11's
Old 04-22-2012, 01:30 PM
think tht rear end well hold up is the 02 rear end better
Old 04-22-2012, 01:35 PM
I'm sure it will let go eventually, especially with the 4.10's. 10 bolts just aren't made to handle much abuse unfortunately.
Old 04-22-2012, 01:36 PM
ya thats wht ive heard...u still have ur 10 bolt
Old 04-22-2012, 01:42 PM
I do, crossing my fingers and hoping it holds up til I can afford something stronger.
Quick Reply: 94 camaro z28 12.41 pass
