12 Second Club In the 12s yet? Come inside!
will the 10bolt hold up
Old 07-09-2006, 02:41 PM
285LT1's Avatar
Default will the 10bolt hold up
I have a 99 SS m6 and i was thinking about putting 4.10's in my car. my question is i'll be going to the track a few times a year. and i was wondering if the 10 bolt will hold up under about 360 rwhp/tq on street tires or possible drag radials. If it won't then i won't waste my money putting in the gears if the rear end is just gonna go anyway.
help me out.
Old 07-09-2006, 04:24 PM
SLPSS99's Avatar
help me out.
My 10 bolt was fine with Full bolt on's, 4.10s and nittos, but it broke right away when I put the MT Drag Radials, cam, and the bottle on On the nittos I was cutting low 1.8 60fts and running 12.1s in the 1/4.
Dan
Old 07-10-2006, 12:32 AM
DOUBT IT's Avatar
A friend of mine who makes less power than you, but same gears, and probably lighter weight, broke the **** outta his twice, then upgraded to a nine-inch. It only lasted 7 passes on Nittos the 2nd time.
On the other hand, you have my car, with over 200 passes down the 1320, stock rear except for a gear swap, and the rear is still holding up fine. Have cut a few 1.6's, along with tons of 1.7's, and I haven't seen past a 1.8 in a while. I am, however, an automatic.
The key is low vehicle weight, eliminating wheel-hop, and in your case, an easier launch. Keep these three things in mind, and I think you'll be okay, or you could **** the rear playing around on the street tomorrow, you just never know with these rears.
Old 07-10-2006, 02:18 AM
285LT1's Avatar
Yeah im a little afraid of that rear end going cuz this is my daily driver, although it does only have 26K on her. i was hoping the 10bolt would hold up. my buddy is running mt et's with a stack of slips a foot high and not problems, but idk its a auto though without a stall. hey man your cuttin some kick *** times with your mods. Juice'd? how do you like those true duals? i have the same setup with pacesetter longtubes that im putting on this weekend. did it make good power? any vids?
Old 07-10-2006, 05:30 PM
DOUBT IT's Avatar
No juice at all. Stock internal. The TSP TD's made a good kick in the *** difference with the Pacesetters. Of course, I did gears, headers, and exhaust all at the same time.
Do a search on the video site under my name and a few should come up...
Old 07-10-2006, 07:12 PM
BriancWS6's Avatar
So far so good here. I have around 20 track passes on my 10 bolt since the 4.10s with Nitto DRs. Countless WOT passes on the street and I have a kickass clutch that results in 1-2, 2-3, AND 3-4 chirps with the DRs.
There's no telling how many passes I made with the 3.42s, this thing has held up to whatever I have thrown at it the last 16,500 miles that I have had it, plus the 25.5k while it was stock before I got it
It may blow tomorrow, but then again I might take this thing into the 10s
Old 07-12-2006, 01:01 AM
285LT1's Avatar
yeah your car rips man thats another good et with your mods, super impressed with your hawk, hoping to emulate your performance
Old 07-12-2006, 01:08 AM
jessedale98's Avatar
I doubt it sense ur an M6, but if you put a rear end girdle/stud kit plus lower control arms, it might last longer.
Old 07-16-2006, 03:14 PM
SuperSport4life's Avatar
I would just get a new rear, I have seen too many people with 6speed f-bods break their rears with abuse. I have even heard of stock power fbods breaking their stock 10 bolt. Just do the rear and get it over with
10bolt=
Old 07-16-2006, 10:10 PM
1Bad97WS-6's Avatar
with my lt1 with hooker longtubs offroad Y pipe with no cats with borla muffler 373 gears with 3200 stall shift kit msd box, with street tires iam turning 1.7s and babying out the hole a little and running mid 8s at 81mph. iam gonna get some m/t drag radial iam hoping for some 8.2-8.3 and some 1.6s for I can take off hard and hope I dont spend. i have the 10 bolt too. i hve 17x9 1/2 front and 17x11 back..
I think I can get some 8.4s with street radials if i work on it.
Old 07-19-2006, 02:39 PM
Lethal_Ws6's Avatar
So this helps out alot or no ?
Old 07-19-2006, 02:44 PM
'02 SLP#686's Avatar
I made about 20-30 passes with most bolt-ons but the stocker only lasted 3 passes with heads and cam. It was on it's way out already though, making noise constantly.
On the other hand - I still drove it home all torn up (about 10 miles) and a junk yard rear was $300 complete... in case you were wondering.
