Advanced Engineering Tech For the more hardcore LS1TECH residents
Polishing Inside of Cast GM pan?
Old 04-08-2013, 11:01 PM
2001CamaroGuy's Avatar
Default Polishing Inside of Cast GM pan?
I'm using an LS7 pan on a build and I am amazed at how rough the interior surface is.
It seems to me that, being a dry sump, it would seem ideal to have the interior surface of the pan be as smooth as possible to promote oil draining to the pickup tube (so it can be pumped back to the oil tank).
Has anyone "polished" (smoothed) the interior of these pans? Would it make any difference? Would it be better to just have the surface teflon coated ($65 local coater I know)?
Chris
Old 04-12-2013, 09:52 PM
ttt.... anyone?
Old 04-14-2013, 06:22 PM
Gordon0652's Avatar
Just leave it.
Old 04-20-2013, 01:29 PM
slowpoke96z28's Avatar
Glyptal promotes oil flow. It was a common racers trick to glyptal the factory lifter valley to help the oil flow back to the oil pan. Maybe you could try that.
Old 04-20-2013, 02:33 PM
Glyptal.... well that's new to me. I'll give it a look. Thanks
Old 04-20-2013, 07:16 PM
subarubill96's Avatar
im with this guy. that stuff works great. have found tons of uses for it too.
Old 09-28-2014, 03:29 AM
trevmust's Avatar
hate to revive this thread but does that stuff actually work?
Old 09-29-2014, 12:19 AM
8 Second Truck Club
Blown06's Avatar
Call polydyn here in texas. They have oil shedding coating that work really well.
Old 10-11-2014, 10:01 AM
cuisinartvette's Avatar
Waste of time on an oil pan
Quick Reply: Polishing Inside of Cast GM pan?
