Mass air flow covertered to CFM???
Using autotap i am see a highest mass air flow of 330g/s or 43.65 lb/min...i tried converting that to CFM using a density of air of 1.184 kg for 25*C...but the CFM comes out to around 590CFM at the throttle body/maf...
where did i go wrong...
Based on some calculations in this thread your numbers are close given the temp.
http://forum.onlineconversion.com/showthread.php?t=253
so my cam only is seeing a max of around 590CFM at the throttle body/maf...good to know
