Sponsored by: DashLynx
Inside of windsheild keeps fogging up!
Old 04-15-2010, 10:17 AM
hlaalu's Avatar
Default Inside of windsheild keeps fogging up!
Every time my car sits in the sun, the inside of the windshield gets some kind of foggy layer that I have to wipe off with a towel/windex. I thought it was the armor-all on my dash, but I took all that off and it's still getting foggy.
My only other idea is that the glue I uses to cover my dash with vinyl is doing this...
Anyone else with a covered dashboard experiencing this?
Old 04-15-2010, 10:39 AM
Gordo78's Avatar
Have you left your windows open in a bit of rain or anything like that? You might also check under your carpet on the pass side. Water collects there when the heater core is getting bad. Could be a reason why it fogs in the sun.
Old 04-15-2010, 11:11 AM
hlaalu's Avatar
it's not water, the "fog" only goes away when i wipe it down (hard) with some windex. it's some kind of film
Old 04-15-2010, 11:43 AM
AZ2ENVY's Avatar
I have the same issues with both of my cars . I havent found out a solution yet to
get rid of it . But it is sure a bitch to get off lol
Old 04-15-2010, 11:53 AM
hlaalu's Avatar
Maybe we can figure this out... Do you have tinted windows or a wrapped dash?
Old 04-15-2010, 11:54 AM
AZ2ENVY's Avatar
Tinted windows on both cars . The film builds up even when it sits for 9 Months out of the year and the doors are hardly even opened .
Old 04-15-2010, 11:59 AM
hlaalu's Avatar
Do you have leather seats? What kind of cleaner products do you use on the inside?
Old 04-15-2010, 12:23 PM
AZ2ENVY's Avatar
Nope cloth interior , F21 , My own special blend of air cleaner spray , Stoners glass
cleaner , Carpet cleaner from Turtlewax .
Old 04-15-2010, 12:24 PM
AZ2ENVY's Avatar
Every piece of the interior including clips , panels , carpet , etc is all mint and new . Hell I even hand washed the floor board when the interior was completely out
Old 04-15-2010, 12:31 PM
hlaalu's Avatar
Interesting... Hmmm
Old 04-15-2010, 12:38 PM
U WISH's Avatar
had the same problem with a wrapped dash..i was told the heat was causing the glue to release gases which left the film on the windshield..i rewrapped the dash using 3M glue and dont have the problem anymore..i dont remember what i used the first time to wrap it
Old 04-15-2010, 01:21 PM
Joshiedoom's Avatar
This and I mine still fogs as well..
Old 04-15-2010, 02:35 PM
02TransAm/Batmobile's Avatar
Try this:
https://ls1tech.com/forums/racers-lo...ng-rain-x.html
Old 04-15-2010, 02:42 PM
shaun's Avatar
im thinking its also the out gas from the glue. almost any glue will out gas wile it cureing but after a will i would think it would stop.
try this take the pad out(i know its a little work but thats how you will know)and leave it in the sun maybe the heat will cure it and if you dont fog up thats the problem.
Old 04-15-2010, 04:28 PM
corpserodeo666's Avatar
It sounds like the heater core might have went bad. Check that and also Rain-X makes a defogger wipes that might help you out. I'm not too sure how well they work but It's worth a try and they only cost a few dollars at a local auto parts store.
Old 04-15-2010, 04:50 PM
dabest09's Avatar
Try not using Windex that stuff is garbage
Old 04-15-2010, 06:50 PM
'Trust''s Avatar
I would try applying some Rain-X to the inside of your windshield and see if that helps. Could be the heater core evaporating coolant on your windshield.
Old 04-15-2010, 06:59 PM
hlaalu's Avatar
Hmmm I'll definitely try the rain x. How do I check the heater core?
Old 04-15-2010, 07:23 PM
Gordo78's Avatar
Fog can be fine condensation from water somewhere in the car. When it gets hot the water may evaporate causing fog. I'm not sure about the film though, that's weird. You might yank up your pass side carpet and see if its wet could be a sign your heater core is bad.
Old 04-15-2010, 07:27 PM
99FormulaM6r's Avatar
Same problem in my Oldsmobile, it's a PITA. The worst part is trying to clean a windshield at a really awkward angle without getting streaks/swirls...
Someone figure this out!
Quick Reply: Inside of windsheild keeps fogging up!
