factory grill
factory grill
hi
please give me the right way to remove the front factory grill ..... step by step ... i tryed to but when i saw the upper and lower cleaps i backed off....so tel me
There are 2 methods:
the fast and easy YANK AND PULL method
or
the slower but more complete TAKE OUT THE CLIPS FROM THE FRONT END, PEEL DOWN THE FASCIA AND REMOVE THE GRILLE CLIPS method.
I used the longer one. It's easy but more time consuming and definitely a PITA. The biggest drawbacks to the yank and pull method are that you lose the clips inside the front fascia and you can't reuse the grille or at least you can't reinstall it since you break the clips off.
or
Originally Posted by Assassin
mine yanked right out and can still go back in, just grab that ***** and pull, estimated work time is about............... 2 seconds!
are you putting on a custom grill or just taking it off because?
if you don't want to re-use it, yank. It sucks anyways. I had the "no grille option" but found this to be more pleasing. after looking at the "whats behind" for a few days.
I used kind of the same method, cept I didnt yank and pull. I more gently moved and tugged, basically pulling each tab out one at a time. For some reason I was worried I would crack my fasica if I yanked too hard with the way it was flexing.
Hey BHARNZ stole my hood..lmao well I did the yank and pull method....worked wonders.....someone else also says to pull out grill a little and cut the 'bolt' lookin think with side cutters....I dunno about that one...I vote yank the B*#%$#d out.
