Smoked/black clear corners
These are the best black corners that I have owned. They never leaged or fogged like the other black ones.
http://cgi.ebay.com/ebaymotors/1997-...item33653cc601
1 Post
I would get the towers where theres LEDs up and down the side and a couple on the top that way you get an even light pattern versus the ones you posted cause those would only sign the light down once you put them in the housings and would kinda defeat the purpose.
1 Post
You'll need EL-12 flashers to make the LEDs flash since there different than regular bulbs. I'm not good at explaining stuff but if you'll search for it, there's a couple write ups on how to install the Electronic Flasher.
There are two basic types on ebay - the really cheapo ones that are ALL black inside (no chrome reflector in the very back behind the bulb) and they melt horribly. They may or may not have an amber reflector dot on the side.
The ones that the Guz linked to (and I had too) have the chrome reflector in the back behind the bulb, and a metal heat shield above the bulb that protects the plastic so it won't melt.
The yellow marker is just a relfector. They are put in there so the manufacturer is able say that they are DOT approved. The depo one's I posted are the good one's. I had another set of all black one's with no chrome housing and they leaked even after I resealed them. I never had issues with the depos.
1 Post
The ones I have in mine came with a set of projectors I ordered from eBay and can't say I've had any major problems with em but idk what there called. The only thing I can say is if we get a real bad rain storm, they will get a little moisture inside but it's nothing to write home about.
Thanks guys. Not a big fan of the yellow marker either.
Guz the link you gave doesn't show a single set for me. Can you post an updated one. Or just post a pic. Im not sure what you mean by "depo".
I've been reading a bunch of the threads on projectors and HIDs and think im gonna do some black sonars and get some 5kish HIDs with smoked or black corners.
Sorry, roarin, don't mean to hijack. Think we have same idea. :-)
Ok Guz I think I found them. I see now "depo" is the brand of these ones on ebay. Found them under "smoke camaro bumper light".. rather than "black ...".
Here's the link..
http://cgi.ebay.com/ebaymotors/1993-...item45f9135b67
Here's the link..
