Camaro Cluster in Trans Am?
So I hate the look of the TA cluster and want to install a Camaro version. I am worried though that some of the idiot lights are located in different areas but am confident the speedo, tach and other gauges should work. Anybody done this? I would be installing the cluster in a 2002 TA. Also worried that GM changed idiot light locations from 99 thru 2002 so maybe some years would work while others not.
I attached a picture of the idiot light locations. Could someone verify this matches their Camaro and what year it's on.
I think the Camaro styling is far superior with the has marks and there's no yellow visible. I also like the red pins on the Camaro.
V6 and V8 clusters are slightly different in a couple spots so I wouldn't compare the cluster in your Trans Am with a V6 Camaro cluster.
All the LS1 based clusters are the same 99-02. 98 might be a tad different. I know the 98 V6 and the 99+ V6 clusters have a few differences.
I did it recently cause I didnt want red, at least untill i get a 6le over lay. plugged in no problems. ONLY ISSUE is that the trip reset button hits the plastic bezel the smallest amount.
before (terrible pic)
after
my idiot lights all moved, but that doesnt matter, they just light up in a different spot.
after
The only thing I like better about the TA cluster is the bezel which also fits the Camaro cluster.
If the lights are in a different location on the cluster, doesn't that mean the pin out is different so the air bag light will come on when you unbuckle your seat belt?... for example.
I just wanted to bring this back to verify that it does work. I have a Camaro cluster in my T/A, only thing is i had to have the mileage changed cause it is stored in the cluster and not the cars computer. I like the Camaro one better, the T/A one was to bland and the red backlit drove me crazy. i have LED's in my Camaro cluster, i also have a Camaro steering wheel.
Same here, when I put all my SS drivetrain into the T/A body, I threw in my gauges as well so the mileage stays with the engine/tranny. Really hated the dark red tint on the T/A gauges. Pulled the bezel from the T/A gauges and put them on the Camaro gauges as well since it's a nice little detail.
2002 Camaro, 1999 trans am gagues
I am doing an LS1 swap into my 2002 Camaro from a 1999 trans am. Moving ECM, BCM, and engine wires. Am wanting to change the gauge cluster, but not sure if it will work. Anybody know?
Thx,
Brent.
Thx,
Brent.
LS1Tech Administrator
Received 1,493 Likes
I know this is old, but since it's back up....
After having owned and spent many years inside of each, I disagree on both counts. Trans Am leather is terrible (especially the shrinking top of the rear seats) and there is no cloth option in the LS1 years, the door panels crack, the switches/*****/buttons are a less desirable color and the steering wheel rim/grip is too thin. Aesthetically I like them both, but overall I definitely prefer the Camaro interior without question.
The only thing better about the Pontiac cluster is this....
.....and it can be added to Camaro, as stated, which then gives you the best of both worlds.
Copy & Paste Moderator
Also, to my knowledge, the quality of leather (and cloth) in the Camaro and Firebird are the same.
I definitely agree here, Formula is the better looking Pontiac and this gives you the option for a much more durable cloth interior. We are in the minority on this, as most people tend to prefer Trans Am. Formulas are hard to find these days though, especially nice ones. Wish I could have bought a WS6 Formula back in '00 rather than a Trans Am, but I waited too long to place the order.
On my '00 Trans Am, I put a ton of conditioner on it from the time it was new, and it was always garage stored, but after just 4 years of driving it on sunny days I was already seeing the beginnings of this problem.
after
after
