Car Wash :O
Car Wash :O
Not 100% sure where to post this because it falls under a few catagories. i picked this section just because its the action that could cause a failure
So my car had a minor... major lol oil leak from when i got the sandwich adapter for my oil filter, so i could get oil tempature. however.. i didnt have the proper wrench/socket to properly tighten the plate.. so i leaked about 1qt. per 24hrs.. not good and especially not a pleasent coat underneath the car...
So here is the question you all have been waitign for lol:
Would i be able to take my car threw an automatic carwash to have the underbody cleaned..
Keep in mind i have a 98' Firebird T/A LS1 so the alternater in on the bottom. Reason i ask this is last time it rained i got forced into a puddle and it did funny things to my volt meter till the alternator dried. this is a brand new alternator if it matters
shouldnt be an issue other then if your lowering makes you bottom out in the car wash potentially. I know I cant bring my Z06 through auto washes with it being lowered 1.5 inches but that car bottoms out on everything. But then I think you being lowered 2" still sits a bit higher with a car vs car comparison.
Do a self-serve bay, jack the car up and spray it. It shouldn't affect the car because the underskirts should protect most of it. And yes, all stock LSx f-bodies have the alternator on the lower drivers side of the engine bay.
Another vote to spray it off yourself. High pressure washes may let a little water in around the window seals.
