Sprinkler
Sprinkler
I'm tired of this one sprinkler in my complex that turns on very early in the morning a couple times a week. Any suggestions on how to get rid of this or adjust it? It is one of the smaller ones, so I'm not sure if its even adjustable, it comes up as a skinny tube from the ground.
I talked to the property manager and he said its managed by the city, so I don't know if I really have any control on this but its really irritating, I want to break it or put something heavy on it so it just gets stuck!
It's this style.
http://www.jvjlawncare.com/wp-conten...prinkler-2.gif
It's this style.
The complex I lived in years ago had theirs set to shoot far out past the grass into the parking lot. They refused to correct the problem, so I got good kicking it when I walked by. It was the same type of sprinkler, the little black head that pops up when it comes on. It was a last resort because they would do nothing and I was sick to death of trying to escape my car being subjected to really heavy hard water spots.
If that is the kind I am thinking of, the top of it should have a gold ring on it? If that is the kind I think it is, if you turn the ring it turns the pressure down that it puts out, therefore making it not shoot as far.
Twist it and see if it will spray in a different direction. Or find a different parking spot.
1 Post
I would just break the thing especially if your having to pay to park there, they should respect your property just as well as you should resepect there's. There made of nothing more than some PVC plastic if I remember right.
Should be able to get a small skinny flat head screwdriver and turn center set screw to turn down the spray. These are the types I have in my yard.
Sent from my HTC One VX using IB AutoGroup
What brand is it (rainbird and toro are the most popular) ? Pictures? I have done a lot of sprinkler installations and most could be adjusted with a flat head screwdriver. If it is the misting kind then you can just gum up the filter. If it is the kind that shoots a rotating stream then it can be adjusted with a flat head. If you break it the wrong way you will get a small geyser and if the grass around it starts to die then they will just fix it anyway and probably keep an eye on you because they know you complained.
