Sponsored by: DashLynx
automatic shifter knob and boot in 99 camaro ss
Old 01-25-2014, 10:49 AM
1SCKLS1's Avatar
Default automatic shifter **** and boot in 99 camaro ss
hey guys I have a 1999 Camaro ss its an automatic and I cant stand the automatic shifter **** it comes with ive seen people put in shifters from the trailblazer ss is it possible that I can put a c5 shifter **** and boot in the car?? has anyone done it thanks
Old 01-25-2014, 11:17 AM
crimson_bird's Avatar
I think both ws6store.com and afterthoughts auto.com carry the adapter you'll need, I got mine from one of them but I don't remember which since that was a while ago. Should be like $25. Then you can use any of the screw on type *****. I used one from hawksthirdgen, a black ball with a firebird on it. I also shorten ended the shady by an inch while I was at it. Finally I added a shifter boot from a late 90's-early 2000's grand am, which fit perfectly. Gotta see if I still have any pics.
Old 01-25-2014, 11:22 AM
jsteele90's Avatar
i bought my boot from redline. lots of custom options, but alot of people do go to the pick a part and just snag a boot from another gm car that has a leather boot.
Old 01-25-2014, 12:06 PM
1SCKLS1's Avatar
thanks man for the helpful information that would be great if you could find those pictures il check out the website thanks
Old 01-25-2014, 12:08 PM
1SCKLS1's Avatar
il check it out thanks man I could use any gm boot?
Old 01-25-2014, 12:15 PM
jsteele90's Avatar
most people just use one from a grand am, grand prix. but most should fit.
Old 01-25-2014, 12:17 PM
99-05 grand am will work, that's what I used. The impalas and monte Carlos from that general time period.
Old 01-25-2014, 12:25 PM
96TransAmboosted's Avatar
Crimson Could you post a picture i was thinking about this the other night. Im sure its much better then the plastic
Old 01-25-2014, 12:37 PM
PontiacFan's Avatar
For example, Grand Prix shift **** with the button on it, & the boot.
Button is now my line-lock.
There are many miscellaneous boots from the GM line-up that you can make work.
This shifter post has been cut 1", the **** recovered in leather, & the boot with it's original plastic frame is simply glued on from the underside.
(The camera flash makes the console cover look a different color, but in reality it matches just like everyone else's.)
So just search the threads for different ***** & shifter modifications, buy an extra console cover if you can & start experimenting.
You might find more threads in the Automatic forum also.
Old 01-25-2014, 02:56 PM
1SCKLS1's Avatar
if i use that boot do guys know if i can use a c5 ****???
Old 01-25-2014, 03:36 PM
Majestic9C1's Avatar
whats involved in cutting the shaft down?? I'd like to do it to mine but I dont wanna screw up the operation of the shaft and inner rod.
Old 01-25-2014, 04:21 PM
I'm guessing he cut and re threaded the rod with a die of the size he needed or wanted?
Old 01-25-2014, 07:05 PM
JDEP162's Avatar
this. i bought the adapter, 25 bucks, and a black hurst T-handle. looks great.
Old 01-25-2014, 11:13 PM
PontiacFan's Avatar
The shift **** in the thread is all about the A4 application.
So there is no re-threading involved.
There are a couple threads in the Automatic forum that shows the cut A4 shifter shaft.
I do not know if the Trailblazer/C5 automatic shift ***** will fit the F-body application. There could be another thread that does show it, so keep searching.
Some people buy the adaptor noted above & in the other posts, from the WS6Store & then add a boot around that also, right up against an M6 shift ****.
Old 01-26-2014, 01:53 AM
Copy & Paste Moderator
VIP1's Avatar
The Trailblazer SS shift **** does fit. I have it installed in my 2001 Formula with a universal black leather shift boot. You just need to trim a tab on the inside of the **** shaft/hole. You'll see it if you flip the TB SS **** upside down and look in.
I don't have any pics of the TB SS **** installed, but here is babbage1109's car:
Here are a couple pics of the stock **** and universal shift boot on my car before I installed the TB SS ****:
http://www.fadingarrow.com/ShiftBoot.htm
Old 02-03-2014, 06:35 PM
1SCKLS1's Avatar
so i need the adapter il get a boot and **** from a trailblazer ss and anything else? thanks
Old 02-03-2014, 06:38 PM
PontiacFan's Avatar
You only need the adaptor from the WS6Store if you are installing a "manual shifter type ****" on to an automatic stick.
The automatic ***** just slide down into place & are held with a 'staple'.
The manual ***** are internally threaded.
So the adaptor threads into the ****, & then the adaptor slides down onto the stick & held in place with a set-screw.
Old 02-03-2014, 10:37 PM
VIP1's Avatar
No need for an adapter to fit the Trailbazer ****. Just a minor trim like it says in my post above.
Old 02-05-2014, 03:21 PM
1SCKLS1's Avatar
ok thanks guy appreciate all the help
Old 05-17-2015, 07:49 AM
wild thing's Avatar
Quick Reply: automatic shifter knob and boot in 99 camaro ss
