Sponsored by: DashLynx
Backlit power window and lock switches
Old 11-27-2014, 03:05 PM
LT4vert's Avatar
Default Backlit power window and lock switches
I didn't want to start another project until the OLED module was complete, but I have some downtime there waiting on parts, so what the hell. I started this with a curiousity if I could pull off getting the stock buttons backlit. I'm happy to report my ideas are working well. Heres where im at so far.
Stock buttons marked out where I want to route out.
Next I had to make a fixture to hold the button for cutting. Worked out flawlessly.
Then taped out the cutlines
Ready for cutting on the mill
Repeated that process with all buttons. Here they are all cut
I used a light diffusing acrylic to fill the holes back in.
Cut the squares out and test fit
Next epoxied them in
The did surfacing work to match the contour of the button
Heres a pic with an led under it.
Thats where Im at at this point. Ive made new window and lock icons in adobe illustrator. I just need to take them friday to get paint templates made. Then paint and coat with a soft touch clearcoat. Fingers crossed that that process goes as planned.
Lastly I had to route out pads and a channel on the stock switch assemblies to facilitate a smd led, resistor and wires.
.... More later, thats all I have done right now.
Old 11-27-2014, 05:55 PM
99'CajunFirehawk157's Avatar
You have way too much free time on your hands, LOL...
KUDOS!
Old 11-28-2014, 12:33 AM
Super-Bat's Avatar
Awesome!
Looking forward to watching progress on this.
Old 11-28-2014, 09:07 AM
LetsRide's Avatar
So its going to cost those of us that want this done how much?
Old 11-28-2014, 06:11 PM
mac62989's Avatar
In for more. Awesome work as always..
Old 11-30-2014, 10:48 PM
LT4vert's Avatar
KUDOS!
I often do, lol I have alot of freedom at work with my time, which thankfully makes small projects like this quite easy to pull off. I only have about 3 hours work in all that though, so not too time consuming.
Letsride- no plan at all. This thread will all be here as a guide if anyone wants to try themselves. The holes I cut on the mill could easily be done without the fixture I made and with a drill or dremel. I went overkill on the process because I could and had the materials.
Thanks for the compliments!! Going to a shop tomorrow to have the transfer stickers of the icons made. Hoping the idea to use them as a paint mask works.
Old 12-01-2014, 07:14 AM
Atrus_SS's Avatar
Badass - hope this pans out!
Old 12-04-2014, 01:50 AM
-Op-'s Avatar
Subbed to see these too. These projects are pretty awesome to see. The free time is awesome to have, and the access to the equipment you have too.
Old 12-06-2014, 08:30 PM
v7guy's Avatar
pretty interested in how this turns out
Old 12-09-2014, 02:41 PM
fbodyrs96's Avatar
Looks awesome
Old 12-09-2014, 09:38 PM
Tipnitty's Avatar
I wish I could do cool **** like this. Very cool man.
Old 12-10-2014, 10:33 AM
LT4vert's Avatar
Thanks guys. Hoping to get more done with them this weekend.
Old 12-10-2014, 07:28 PM
-Op-'s Avatar
Sweet. Definitely want to see that
Old 12-25-2014, 01:14 PM
Jeff Smith's Avatar
That s cool switches..
Old 12-30-2014, 07:59 AM
drain89's Avatar
Excellent work so far!
Old 01-29-2015, 05:58 AM
v7guy's Avatar
Any progress on these?
Old 01-29-2015, 05:42 PM
LT4vert's Avatar
Its on my desk in the to do pile. The time I had to get the stencils made, my usb stick was having issues at the shop and couldnt pull the files. Ive got a new flash drive and have the files on it, just need the time to get back over to the shop thats going to make them.
Old 01-30-2015, 07:18 AM
Atrus_SS's Avatar
Where did you get the acrylic? It could be useful in my custom dimmer setup - was planning on "frosting" (lightly sanding) clear plexi, but this would probably work better.
As for stencils - what's the plan? Use some type of cut vinyl product as a stencil, paint the switch, and carefully remove the vinyl?
Old 01-30-2015, 11:35 AM
LT4vert's Avatar
That is the plan with the stencils man. As for the acrylic, its from a company called plaskolite. Its in their optix line and its just a white led light diffuser. They have a few white with various densities, the one I got was 7328 white. I just requested manufacturing samples so the cost was very minimal.
Old 01-31-2015, 08:49 AM
Kevin97ss's Avatar
Are you doing the stencils yourself or do you have a "guy"?
I'm looking for a way to do very small lettering on the turn signal stalk. A stencil and vinyl dye is what I was thinking.
Quick Reply: Backlit power window and lock switches
