Mini H1 Projector Cutoff Issue
Looking for some help here. I retrofit a pair of h1 mini projectors into my stock c5 headlights. Im having an issue after getting everything setup where Im seeing a double cutoff on each side.
I played around with the adjustments some but I'll finish it up this morning. The issue I'm having right now is that I seem to have a fainter cutoff line on top of the real cutoff. I kind of saw this when I was testing the projectors outside of the headlight assembly but I thought it was because I didn't have the correct bulbs and I was just pressing them into the projector and holding them in place with my hand.
I'm thinking the bi-xenon cutoff shield might be causing this but I could be wrong. I'll try and research it and figure it out. Either way they are a million times better than the output the ebay aca style lights came with stock.
This shows the faint second cutoff line.
this is the left headlight with the right light blocked.
I put my hand over the headlight and was able to block the second cutoff lol. I wish it was as easy as that.
Here is the highbeam with the bixenon shield flipped down.
Hopefully I can get the second cutoff figured out. I did the same retrofit on my 4th gen camaro headlights using the same projectors from the same ebay vendor and I didn't have this issue.
same setup in my camaro
I wonder if it is something simple to fix or if i need a better quality projector like the morimoto ones.
Sounds like a lot to look at lol. Are these things I would need to check on the morimoto brand ones also. If i can buy those and not have to worry about it Ill fork over thr cash for some.
Sux though because the first pair i bought from this vendor had no issues. I guess what can you expect for $40.
Copy & Paste Moderator
Does the output still look like that when the projectors aren't in those housings? I'm wondering if something in those housings is causing a reflection.
Yeah the output was the same when i had the projectors out and was aiming them at my garage ceiling. At that time i was holding the headlight, holding the bulb in place and touching the battery contacts lol. I kind of thought maybe it was because of the wrong bulbs and because they werent securely mounted in the projector.
Those mini H1 projectors are a hit or miss. If you got it from TRS, I would send it back and ask for a new one, they have great customer service. One of mine was perfect, and the other one had a weird yellow cutoff to it and wasn't blueish/purple like the other one near the cutoff. I had to mess around with it a lot to get it better.
That double cutoff can happen if the shield isn't flipped all the way up and is angled. If I were to do it over I would've used another projector.
Well I finally got a chance to play around with the headlights again. Thank you all for the help it was in fact the headlight lens. Can't do much about it that I can think of so for now I will just stick with this setup. Still works better than the stock headlights.
Below are a couple pics without the headlight lens in front of the projectors. I think the $40 ebay projector looks better than the $120 morimoto.
Ebay projector without headlight lens
Morimoto projector without headlight lens
I tried placing the lens in front of the projector at different distances with pretty much the same results.
I also tried installing thr projector in the high beam location hoping it would pass the headlight lens at slightly different angle preventing the double cutoff but it does the same thing.
