how do you take off the emblems?
i wanna remove the stock z28 emblems and put some older style ones on.
how do you remove the old ones while keeping them intact?
also, how do you attach the new emblems on there, i want to put the 1st gen emblems.
i plan on attaching them on the fenders, grill and back.
if you heat it up with a hairdryer you can risk damaging your paint.
The best way is to go to a body shop and get a glue removal wheel (might take 2 for several emblems), and some heat adhesive for removing emblems, I don't remember what it's claled but you can ask them, use that to take it off and then the wheel to erase the glue thats left, without damaging your paint.
Hair dryer and dental floss or fishing line.
When you get the new emblems you have to cut the pegs off the back if they have some, then hop on over to autozone or someplace and get some emblem adhesive weather resistant and cut it to fit the back of your emblems.
Originally Posted by parbreak
Paint can withstand a lot heat. Use a hairdryer or better yet a heat gun that you can set the temp on. Heat it up and I use dental floss to separate the emblem.
Dental floss though...i'll have to try that.
A heat gun can hurt the paint but only if its on HI heat and you keep it in one spot for a long period of time. But by that time the emblem prob fell off, so you are there for your health lol
Originally Posted by andypdbz
hmm, i can use the fishing line without heating up the emblems?
so how else can you attach the new emblems?
I just did mine today, only problem I encountered was my passenger side emblem was previous removed when I had the 1/4 panel replaced due to a deer months ago. The trick with the hair-dryer didnt work. I ended up using fishing line to "floss" it off. Then had my mom use her nails to scratch off the residue
The original side worked perfectly with the hair-dryer trick. I preped the area cleaning it with dishwash detergent & water, then heated it up, flossed it off, and it came right off. All i needed was some Goo-Off and some scrubing with a sponge and it cleared off. I also hit the area with wax too when I was finished. Both sides look perfect!
You can, but heating it up works better. Its like using a warm scooper vs a cold scooper to get ice cream out of the tub. Both work, but when its warm it works better.
