Sponsored by: DashLynx
Check out my new RED tail lights...
Old 09-03-2005, 11:35 PM
6LITEREATER's Avatar
Default Check out my new RED tail lights...
What do you guys think? Scroll down slightly for pics:
http://www.cardomain.com/ride/814502
Old 09-03-2005, 11:47 PM
SSU's Drunk Typing Whore
Lithium's Avatar
Its different. I like it, how did you do that? or find the lights?
Old 09-03-2005, 11:52 PM
I used translucent red paint from the hobby store. The third-gen guys have been doing it forever.
I like it because it reminds me of the Vipers. It'll look much better after I install a Berger style panel IMO.
Old 09-04-2005, 12:27 AM
Lithium's Avatar
Cool, I may do that now I really like how it looks. What was the exact paint you used? and the process of how to do that? Thanks.
Old 09-04-2005, 12:31 AM
meissenation's Avatar
Only the second time I've seen this done on a 4th gen, but I think it looks good that way. If only there was a way to get rid of the black lines, so it really would be all red.
Old 09-04-2005, 01:29 AM
I simply cleaned the lenses with rubbing alcohol, taped off what I didn't want red, and sprayed (MANY light coats) of a translucent red paint (said it was good for plastics, got it from a local hobby shop).
If you didn't tape off the black lines (as I did) you could pretty much get rid of the black lines and make it close to all red.
Old 09-04-2005, 09:10 AM
ls2 bait's Avatar
anyone tried to make the turn signals clear and use an amber buld like the clear corners? thats the only part on my car that doesnt match anything else and it kind of annoys me.
Old 09-05-2005, 01:23 AM
CULATR's Avatar
DEMONBIRD hey im going to try that (red tailights) and any info and help on it also what was the name of the paint you used that looks awesome im digging the way the slants in the middle light up is that your brakes i like that alot let me know email me all info you can to hsbr6969@yahoo.com thanks.........brandon
Old 09-05-2005, 04:38 AM
The "slants" is actually just caused by the flash.
It's really straight forward, TAKE YOUR TAIL LIGHTS OFF THE CAR (don't want to end up with overspray on the car).
Then just clean the lens with rubbing alcohol. Let that evaporate then tape off the part you DON'T want red.
Make sure you tape along the lens COLOR edge (be it white or amber). NOT the edge of the plastic that it is made of. Tape OVER the black part following right on the edge of where you see the color.
It's just hard to put into words but you will see when you start. You want to only paint the area that is clear or amber NOT ANY BLACK area or it will look weird.
Spray it in LIGHT coats, let it dry, then spray again. I painted it outside in the daylight letting the sun dry it fast.
I used a full can (which is a SMALL can, not the normal spray paint can size) between the two lenses.
I don't remember the exact brand but just go to ANY hobby store and get a can of TRANSLUCENT RED and you'll be good to go.
Test the color on another object first. If you like it, spray away !
Old 09-05-2005, 12:56 PM
Black98Z28's Avatar
that looks really badass....so u spray the outside of the lens? or the inside?
Old 09-05-2005, 01:43 PM
I sprayed the outside.
If you could spray a car clear coat on it afterwards that would be even better.
Old 09-05-2005, 03:16 PM
Amorget's Avatar
Why not get the 93-96 LT1 tail lights instead?
Old 09-05-2005, 05:24 PM
I already had these .
Old 09-05-2005, 07:06 PM
Reject's Avatar
man thats bad ***! hey could you take some backing out pics and some turn signal pics with some steping on the brake pics? wanna see how they light up, is that state legal btw?
Old 09-05-2005, 11:32 PM
I'll try.
Old 09-06-2005, 10:02 AM
Trev_SS's Avatar
i would never do that i like how the lights look stock, whenever someone starts messing with lights i just think that it look ricer, the only lights that dont look ricer is the clear corners thats just my opion though
Old 09-06-2005, 10:07 AM
Reject's Avatar
Old 09-06-2005, 11:12 AM
camar0guy's Avatar
u should definitely put a coat of clearcoat, ifnot within a few months ull notice the fade, those hobby colors tend to do that, i did that to my bmw and its still holdingon good
Old 09-06-2005, 12:28 PM
abadss's Avatar
cool idea, looks different. i just wonder how you will do with inspections? dont turn signals have to be amber?
Old 09-06-2005, 12:36 PM
Amorget's Avatar
No, look at LT1 (less 97) taillights...
Quick Reply: Check out my new RED tail lights...
