Sponsored by: DashLynx
Anybody buy these $24.00 clear corners?
Old 09-15-2005, 01:36 PM
gkrocket's Avatar
Default Anybody buy these $24.00 clear corners?
I found these on Ebay and was wondering if anyone had bought these and if the quality was acceptable.
http://cgi.ebay.com/ebaymotors/CLEAR...temZ7997189857
Old 09-15-2005, 05:40 PM
gkrocket's Avatar
Well I bought em'. If anybody is interested I'll post what I think of em' when I get em'.
Old 09-15-2005, 05:50 PM
AntiVenom06's Avatar
I think thats the ones I have
Old 09-15-2005, 10:36 PM
Arachnotron's Avatar
Just seal them with some clear RTV around the seam where the lens and the housing come together and you should be fine.
Old 09-15-2005, 11:04 PM
Brian2006's Avatar
Yeah because if you dont they'll turn like this:
and then you'll have an ebay seller that won't send you new ones.
Old 09-16-2005, 11:21 AM
Kirby's Avatar
The main cause for condensation in your DRLs is because the rubber seal on the 3157 bulb connector is bad or in my case, missing. I have even seen some people drill a couple of small holes on the bottom and on the back. These locations keep water from splashing into the light and allow the condensation to escape when the bulb gets hot enough to evaporate it.
Old 09-20-2005, 03:09 AM
gkrocket's Avatar
Thanks for the input. I live just outside of New Orleans so the mail is really slow right now, which is better than having no mailing address at all like some folks are having to endure, we were fortunate. But, when I get em' I'll let ya-all know how it turns out. Thanks again, I will put RTV around the seal for sure.
Old 09-20-2005, 10:50 AM
Kirby's Avatar
Just make sure you get the clear RTV or else it will show in the inside edge of the light housing. As you can see in the pic above, the left side is toward the center of the car and you can see the edge of the light. You don't want to get any black, blue, or red in there because it will definitely stand out and not look as professional as if it were not noticeable.
Old 09-21-2005, 02:35 AM
rotwiler's Avatar
I tried to seal them and didn't work, then about 3 months later I decided I was tired of the water in the lights and removed them. Only to find out the heat from the bulbs warped the back of the housing and caused them to get water in them. I ended up just getting some covers and reusing the stock lights. Plus after the moisture was in them for a few weeks they started looking like the backside of aluminum foil, the dull aluminum look in little spots all over.
Old 09-21-2005, 06:39 PM
ritchie's Avatar
Ditto.
I've had so many people say to put sealant around the edge where the clear lens and housing meet. I hate to say that in my particular case, that wasn't the issue. The issue was where the bulb screwed into the housing. The bulb sat a bit loose, and water leaked in from the gap between the headlight and bumper.
My suggestion is to make sure the bulb sits correctly in the housing. Use some 3M double sided tape or sealant around the bulb.
(BTW, once I did what I mentioned above it was problem solved)
Old 09-23-2005, 02:23 AM
Juiced2000SS's Avatar
I had the ebay ones at first and didnt care for the bulbs showing and i did get water in them after the first time I washed it. I went ahead and got the more expensive ones from RK sport. They have the reflector type clear lens that is just like factory and no problems yet.
Old 09-23-2005, 07:20 PM
USMARINE1108's Avatar
I've had the RK sport clear corners for about 7 months now with no problems.
Old 09-24-2005, 02:15 PM
iroc626's Avatar
I bought those, didn't use sealant and have had no problems w/condensation. Just make sure you use the rubber bulb housing gasket. BTW...I opted for the "chrome" bulbs from auto zone. They dont look orange when they're off.
Old 09-24-2005, 05:08 PM
LS1MONSTER's Avatar
I've had RKsports clear corners for a few years now. They did get water and condensation every now and then. An easy fix for that was just drilling some tiny holes underneath the lenses. Problem solved.
Old 09-24-2005, 05:18 PM
NYC FRANK's Avatar
Talking
Same here with the RK sport lenses. I get moisture in there and It kills the bulb (about 1 a month!) I gotta check cuase I think the rubber O ring on bulb connector is missing.
Old 09-24-2005, 06:21 PM
02NBMSLPSS's Avatar
Thanks for pointing that out i never checked for that. Mines doing the same ****!
Old 09-24-2005, 09:37 PM
thunder95ta's Avatar
Everything that looks good isn't.
Old 09-24-2005, 09:55 PM
klw1313's Avatar
man mine did that condensation crap the first night!!
Old 10-13-2005, 07:07 PM
gkrocket's Avatar
Well I guess I'll find out. I just put them in tonight. I forgot about sealing them with RTV. I'll have to go back and do that. I didn't get the first ones I ordered. For some reason they wouldn't ship them to my address. I got these,
http://cgi.ebay.com/ebaymotors/93-02...temZ8006920910. If I have any trouble I will update.
Thanks for all the input!
Quick Reply: Anybody buy these $24.00 clear corners?
