cobra shift knob
Here is a little write-up I did for this mod
https://ls1tech.com/forums/appearance-detailing/246893-cobra-shift-knob-questions-answered.html
Originally Posted by DVST8OR
I re-tapped my Cobra ****. This may not be the best option for some because you need the right tap & drill bit but it does allow you to continue using Camaro shift ***** if you decide to change it out again.
I drilled and tapped the Cobra shift **** also. It does take some equipment, 2 drill bits, the special M16x1.5 tap, and preferably a drill press. Other than that it was much easier I thought than changing the shifter stalk.
J/K
It has looked nice in his car for over 2 years.
