Sponsored by: DashLynx
Aeroforce interceptor gauges
Old 01-03-2006, 07:48 PM
blacksnake's Avatar
Default Aeroforce interceptor gauges
Does anyone know for sure if the coolant temp parameter works on an 02 F-body. Or which of the other parameters work/don't work.
Also, were would be the best place to mount just one gauge.
Thanks in advance for any help.
Old 01-04-2006, 01:52 AM
ArcticZ28's Avatar
Coolant temp works. I just picked up one of these guages as well. I've yet to install it as it's a 4th gauge I'm trying to figure out where to put. Not sure where I would mount just one gauge though...
Old 01-04-2006, 03:48 PM
SUTTERERMAN85's Avatar
i want one. where are you guys getting these at? i have only seen them on ebay. any sponsors have them?
Old 01-04-2006, 04:00 PM
you2slo's Avatar
New Era and PFYC.
Old 01-05-2006, 11:29 AM
thanks
Old 01-05-2006, 01:26 PM
Ferocity02's Avatar
Someoneb who has one of these installed needs to sack up and tell us what the gauge actually reads off. Arctic, maybe you could just plug it in to the OBDII port and write down what parameters actually work on it. Thanks!
Old 01-05-2006, 01:55 PM
1998TA__1991RS's Avatar
what about down by the cig lighter, whats the difference in the dual and the single one?
Old 01-05-2006, 02:05 PM
Bigrob339's Avatar
I have one of these gauges hooked up, i havent seen how it the parameters work on the road, but i have watched them when the car is idling since it is winter here. The only thing that it will not read is oil pressure. I am still figuring the gauge out, i dont know what long and short fuel trim is?I guess is something with fuel injectors but not sure, anybody know the diff? The gauge is badass though.
thx rob
Old 01-05-2006, 02:07 PM
Ferocity02's Avatar
I think dual just means you get two gauges instead of one. So you would have four displays. I think one would be sufficient. 85% of the reason I would get one would be to read and clear DTC's, and you only need one gauge for that.
Old 01-05-2006, 02:08 PM
SMDLS1's Avatar
Ill second that!!!
Old 01-05-2006, 04:16 PM
blacksnake's Avatar
Thanks for the replies. I guess I'm leaning toward putting it down by the cigarette lighter. I'm searching for the cleanest, easiest installation. I considered the pillar, but I'm not sure I want it up there, and do they even make a one gauge pod?
Are there any good write ups (installuniversity style) for gauge mounting?
Good luck with your gauges/installations.
Old 01-05-2006, 05:05 PM
ArcticZ28's Avatar
Originally Posted by SMDLS1
Ill second that!!!
I'll try and do that soon so everyone can know for sure. I'm in the middle of a wash/clay/wash/polish/glaze/wax with the new porter cable so it'll have to wait until that's done
Old 01-05-2006, 06:37 PM
Ferocity02's Avatar
https://ls1tech.com/forums/appearance-detailing/426551-console-mounted-gauges-take-look.html
Too bad you missed out on my little sale. You can make them yourself though, assuming you have the material and proper tools. I will make another round in early April and will offer more materials.
Quick Reply: Aeroforce interceptor gauges
