Sponsored by: DashLynx
zaino question, answer quick please!
Old 02-09-2006, 08:10 PM
camaroextra's Avatar
Default zaino question, answer quick please!
Ok iv spent the day doing the different zaino steps. about 3 hours ago i put on z-5 and that **** still isnt dry! it was warm earlier but now its 60-65ish outside (in my garage)
so no harm done in driving it to the gym with zaino all over it right?
just want to be sure
Old 02-09-2006, 08:13 PM
ZaneO's Avatar
Something is wrong...How much did you apply? Did you use ZFX with it?
If you drive it and then remove it, there's a chance that you could scratch it from dust, etc. settling.
Old 02-09-2006, 08:24 PM
zfx is the accelorator right? then no i didnt. i aplied a liberal coat, but i didnt pour it on (iv done this before) i usually check by taking my finger and wiping a little bit, and if it kinda dusts off ill take it off, but if it smears ill leave it.
should i just take it off with my orbita buffer? or will that have wasted all my time
Old 02-09-2006, 08:45 PM
ZaneO's Avatar
Well, for 1 coat, you should have used about 1/3 oz. Much more than that and it's *way* over-applied.
You should *barely* be able to see it go on. "Liberal" coats and Zaino don't mix...it leads to greatly extended drying times (as you're noticing).
If it is still smearing, an orbital buffer probably won't take it all off. I don't recommend that method of removal in any case really.
It's just going to take time and possibly a Z7 wash tomorrow.
Old 02-09-2006, 08:53 PM
yeah your right, the orbital didnt do ****. ill just take it off tommorow. i really need to start reading instructions before i do things
im gona take an applicator and try and scrape it a little thinner so it dries overnight
Old 02-09-2006, 09:03 PM
ZaneO's Avatar
If I were you, I would just let it sit on all night and all day tomorrow. Tomorrow evening, give it a wash with Z7, and you should be fine.
Old 02-09-2006, 09:06 PM
thats not an option, i have school and im going to the track, dont have any other cars to drive
Old 02-09-2006, 09:15 PM
ZaneO's Avatar
You can drive it, but it will need to be washed instead of normal removal.
Old 02-09-2006, 09:18 PM
i used an applicator to thin is out, so tommorow i should just wash it wth the zaino wash. it wont just wipe off when its dry like it should?
Old 02-09-2006, 09:32 PM
ZaneO's Avatar
Sometimes when there is just too much excess, it won't really dry...kinda like when it's in the bottle, it's just sitting there with nothing to bond to. What is actually touching the paint should be dried/cured by then.
A wash should take care of it.
