To relocate or not to relocate (coils)
Need some opinions. I am looking into some Nasty Performance Valve covers and leaning toward Thunder's coil relocation kit, but a little worried about the wires hitting the headers and creating a problem. For those who have done this, what are your positives and negatives? Should I relocate the coils since I will be spending $350 in Valve covers? Here is a current pick of the motor.
Thanks Guys!!
Thanks Guys!!
I'm in the process of making a coil relocation kit that will basiclly be the same as the Thunder kit, but with fully polished brackets and spacers and cost about $50 less. I plan on using MSD 8.5 mm wires red or black. Plus my kit will come with detailed instructions unlike the Thunder kit.
If you can wait about 3-4 weeks max this biz "Chrome & Performance" will be a sponsor here. ~Joshua
I made one for my car already a year ago, but now I'm doing a prototype that I will use to base the mass produced kits on. The one on my Firehawk is perfect and hasn't been a problem in any way.
Brian, I have the Thunder kit with absolutely no problems to speak of. The only changes I made to the kit were to replace the hardware with all stainless and I had the brackets powdercoated satin black. I used Taylor's 10.4mm plug wire separators when routing/organizing the plug wires...if you are careful about the wire routing, you shouldn't have any problems with the wires touching the primaries...mine aren't even close (relatively speaking, of course)
I have the Thunder Kit and 10.4 Taylor's also. Also, just happen to be getting some Nasty valvecovers that should be in sometime in the next week. Getting mine directly from the company that supplies Nasty. Haven't had any problems with my wires or relo and I've had it for over 2 years now.
Originally Posted by DEMONBIRD
Isn't it better, performance wise, to deal with the aesthetics (or lack there of) rather than have longer plug wires???
That's why you spend the money on the 10.4 mm wires so you can go longer.
1st and 2nd gen smallblocks, both street and race engines revving up past 9,000 rpm have been doing fine with long wires and ONE coil.
The LSx engines have ONE COIL PER CYLINDER!!! More than enough power and there is ZERO performance to be lost by going with typical sized plug wire. The fire will be lit just fine if not better than all the older engines for the one-coil-per-cylinder fact alone.
Thanks
What height is your covers?
Looks like from the other posts as well, no one seems to have any problems.
Originally Posted by Brian2001SS
It will end up probibly being three weeks for I order, so I will wait and see how yours comes out. PM when you get some idea when I could order.
Thanks
Thanks
