Sponsored by: DashLynx
Need help with crap on paint
Old 05-31-2006, 10:08 PM
02wS6firechicken's Avatar
Default Need help with crap on paint
Hey i have this crap on my front bumper, its kinda like a road grime that doesn't come off. I tried meguiars cleaner wax but that did not work. My car is also dirty and there are bugs on it but its all the little white smudges on the front bumper. What do you suggest to get it off.[IMG][/IMG] [IMG][/IMG] [IMG][/IMG]
Old 05-31-2006, 10:10 PM
LS144's Avatar
Caly bar should get rid of it all.
Old 05-31-2006, 10:14 PM
NightWindDriftr's Avatar
Try the clay bar first. It looks like some bugs are thrown in there too - you shouldn't be even thinking of wax without a properly prepped surface! If the clay bar doesn't do it for you (and it should), you may have to turn to some mild abrasives.
Let us know if the clay bar can't tear that junk off.
Old 05-31-2006, 10:19 PM
Scotty-Z's Avatar
Try some Bug and Tar remover from your local auto store. Then buy a claybar and go over it. Work over it continuously with that (might take a couple tries at it) and once you have it feeling like glass, give it a good wax.
Old 05-31-2006, 10:23 PM
Brian2006's Avatar
Sometimes if you leave squashed bugs in the sun, acid in them eats away in the clearcoat. So if the claybar doesn't get all of it I would say you're pretty much screwed
Old 06-01-2006, 12:43 AM
do u think a mild buffing compound would do the trick?
Old 06-01-2006, 01:28 AM
Couchman86's Avatar
Hey man I've got this stuff made by Gunk, called Tar&Bug remover. It works alwsome and won't hurt your clear coat. I used it to remove tar from my car that the previous owner had gotten on it. It does the trick and only cost me $1.99 at O'rielys
Old 06-01-2006, 02:27 AM
DavidH426's Avatar
I would clay the car first to get the paint clean smooth as a baby's rear. Then I would use 3M perfect-it II #39009 Swirl/scratch remover glaze with a porter cable #7424 with a white buffing pad. Then I would buff again with a black pad. The 3M is one of the least abrasive products to try first. After that I would put numerous coats of Zaino Z-2 on the car. Then you would not have any problem with bugs/tar etc... sticking.
Quick Reply: Need help with crap on paint
