Sponsored by: DashLynx
Before & After engine bay
Old 09-10-2006, 02:21 PM
RoastEmSS's Avatar
Default Before & After engine bay
This is how it was when I bought the car, a bloody mess
Here it is today, looks a lil plain, but much better IMO
Old 09-10-2006, 02:28 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
I like the 'after' better.... It has a cleaner, smoother look to it.
Nicely done.
Personally, I'd paint your intake black to match the car and continue with the theme.
Old 09-10-2006, 03:22 PM
litemup02's Avatar
Yes, much better. My S-10 extreme was the same way when i bought it. COVERED in red wire loom .......until i got home that is!! I mean who actually pops the hood to show a 2.2L 4-banger. I mean it is pretty EXTREME
Old 09-10-2006, 03:24 PM
nokeman's Avatar
Looks much better. It looks much sleaker and simpler. Nicely done. That FAST looks right at home...
Old 09-10-2006, 04:01 PM
Andros's Avatar
u can paint the fast intake
Old 09-10-2006, 04:30 PM
RoastEmSS's Avatar
seems like its a lot easier to work on too,prolly just in my head tho, im not painting my $800 intake BTW until i get the ***** to anyways
Old 09-10-2006, 05:00 PM
LS1DER's Avatar
Thank you for doing all of us a favor by taking all that red crap out. Looks much better.
Old 09-10-2006, 10:27 PM
LS1 Sounds's Avatar
You can also paint the backs of your headlight housings black. I just did mine in semi-gloss this afternoon, along with the trim pieces between the lid and front bumper cover. The headlights were very easy: just pulled them out, cleaned with Simple Green and a brush, took off the small clips and the rubber drain elbows, taped off everything from the lens forward, and sprayed it with a can. It was dark before I finished putting them back in so I couldn't really check out the results. I'm afraid it's going to cause some of the other bracketry to look faded though, good thing spray paint is cheap.
Old 09-10-2006, 10:39 PM
Y2K Pewter SS's Avatar
I apologize for hijacking here,
I just did mine the day before, came out great.
And to get back on topic, it looks much better without the red clutter.
Old 09-10-2006, 10:40 PM
RoastEmSS's Avatar
the black headlights look great! ill prolly do that tommorow, thanks!
Old 09-10-2006, 10:43 PM
After you clean them up, be sure to scuff them up with scotch brite pads so the paint will adhere better. I used an adhesion promotor as well.
Old 09-10-2006, 10:45 PM
RoastEmSS's Avatar
yup, got steel wool, adhesion promoter, gloss black engine enamel, then clear coat eng. enamel
Old 09-10-2006, 10:46 PM
Silver02TA's Avatar
well i can't really see the after pics... dark as hell
Old 09-10-2006, 10:49 PM
Exactly what I used, you will be a pleased man afterwards
RoastEmSS's Avatar
better? i need a freaking tripod or somethin..
Old 09-10-2006, 10:52 PM
99camarosupersport's Avatar
Looks like someone stole your air bellow...and do you always run no MAF?
Old 09-10-2006, 10:57 PM
RoastEmSS's Avatar
those pics r a couple weeks old, im not sure y the bellow was off, and yes i never run the maf, speed density tune
Old 09-10-2006, 11:04 PM
8banger's Avatar
Who did the tune?
Old 09-10-2006, 11:05 PM
RoastEmSS's Avatar
local guy named scott evans,his name is soundengineer on tech
Old 09-10-2006, 11:45 PM
LS1 Sounds's Avatar
Damn, I hope I don't end up having to redo mine. I didn't scuff them up at all!
Side note, are those bolt covers you are using or are the heads of your trim bolts that huge? Some of mine are starting to rust, which I wire-wheeled today and also sprayed black to stop the rust. I want to replace them with something nice though.
Quick Reply: Before & After engine bay
