What is this???
What is this???
I got my car painted recently and this has surfaced all over the car. What is it? I had a friend paint it and I am reluctant to say anything, it's a long story, don't ask. It needs to be taken back and I will go about that another way so I don't need advice there. My question is what is this and can I, the novice detailer, remedy it? Washing it does not remove it nor does 3M finish restorer. I imagine it will need rebuffing or is it from over-buffing?
I'm pretty sure it's not overspray. I think it's orange peel and the compounds have settled into the pits. I was afraid to sand on it. Reckon a polisher could smooth it down? Or would it have to be buffed? (Provided my theory of orange peel is accurate).
That my friend looks like solvent pop which means your friend is not that good of a painter. Without seeing it in person, that is my best guess and that can happen from a variety of factors including: poor prep, incorrect reducer used in the base coat, not allowing enough flash time between coats and so on.
I found this link. http://www.sherwin-automotive.com/re...ping/index.cfm
Looks like that is for sure what has happened here. Is it in the realm of possibility that this can surface later? I mean I didn't really notice this at first.
Yeah it looks like I'm gonna have to. Only bad part is I am afraid this is gonna be a mess to sort out. I really want to get my money back and buy a white car as a donor.
Just learned the same lesson you did. I had a friend paint my SS spoiler and he did a **** job. Now I have to take it back to him to make him redo it and hes been avoiding me. i have the same bubbles, some drip marks and other imperfections. He did it for very cheap but trust me, i would have rathered paid the money and gotten a good job. lessoned learned i geuss.
Yeah lesson learned. I just hope I can recover some funds. I believe I am going to buy another car and put my driveline in it. I am sick of this black paint ****. Probably save the body for another project. Next time I will take it someone who can do it right. I'll have it stripped down and painted a different color.
Originally Posted by TUMBLRws6
what does "flash" mean???
Bryan
parbreak
Originally Posted by dhdenney
Yeah I found that out! Don't let your friends paint your vehicles cuz you get into a pickle like I have done! There's not much way to smooth that off without redoing it?
Good news. The guy that painted it seen it and he is going to give me my money back. I am buying a red Z with Baer brakes at all 4 corners as a donor. This is gonna work out fabulous after all!
As paint dries, it "flashes" off which means the solvents are evaporating. That is why you have to follow the manufacturers instructions for re-coat times. In other words, if they suggest waiting 15 minutes between each coat of base color and then wait 45 minutes before clearcoating, you better do that, otherwise the solvents do not have time to rise to the surface and flash. If you lay on succesive coats then the solvents in the lower coats get trapped and do not flash. Well, eventually they will flash in terms of what you see in the above picture: bubbles or "solvent pops"
Bryan
parbreak
Bryan
parbreak
I couldnt of said it any better. thats is also why you cant wax new paint for 30 days because the paint is still breathing and letting the chemicals out.
