LED Brake-Lights...complete with pics & vid
Well I finally finished everything up. I replace all of the exterior lamps with LEDs except for the fog lamps and headlamps (HID). I had the front corner lights finished a little while ago but went ahead and did the tail lamps including the brake lights, 3rd brake light lamps, rear corner lamps and license plate lamps.
The interior is also totally outfitted with LEDs except for the original factory guages. Map lights, door lights, back seat, ash tray and autometer guages all have LEDs as well. Below are pics and also a quick vid I threw together to show how well these LEDs work in the tail lamps. The only one I'm not thrilled with is the license plate light but I can fix that another day. Enjoy.
And for a little comparison, here are the original lamps at night.
Click here for the video (I just uploaded it so if its still optimizing, check back soon)
Click here to see Video
I'm loving the quick on/off operation.
-Brian
-Brian
pictures were taken at two different times. The brake lights are now a bit brighter than they were and their operation is much quicker. I was planning on doing a simple comparison from tail lamp to tail lamp but I had some install issues and I didn't feeling like tearing everything all up again to put the original lamps in. Maybe if I'm bored I will do that tonight or tomm. The vid works now so you can see the operation.
-brian
-brian
I´ve installed those over two years ago and they still work...
It is only one thing i dont like the difference between brake and when the light are on could have been better you notice this when you use them in the daytime.
Every bulb on my car except high,low,fog are LEDs.
-brian
My tail lamps use 3057 lamps for the brake lights. I purchased these from a non-sponsor so PM me if you want the details. The electronic flasher I purchased was the EL12. I needed two, one for the turn signal and one for the hazards to replace the existing thermal flashers.
-brian
-brian
Nice work!
However I prefer the look of the regular stock light bulbs in our Fbodies. Mainly because of how the light bulb lights up, taking a second to reach full brightness. I think it just looks more classic this way, other then the "instant" flash from LED's.
Originally Posted by _JB_
Looks nice, but how about a picture in direct sunlight?
-Brian
