Sponsored by: DashLynx
What type of pad for swirl remover?
Old 04-21-2007, 02:06 PM
DirtyBird222's Avatar
Default What type of pad for swirl remover?
What type of "pad" should I buy to apply swirl remover with a low speed "buffer?"
Same question for applying polish? Can I buy this stuff from Discount or Autozone?
Don't tell me to buy a tropi-care porter cable or some other brand I don't have the money, I'm just borrowing my next door neighbor's and he uses it on his 51 GMC truck that's mint so I'm fine with using it on my car
Thanks in advance
Old 04-21-2007, 03:09 PM
TTT?? com on I know there are a million of you appearance ****'s like me out there!
Old 04-21-2007, 03:39 PM
jargan04's Avatar
Depends on what kind of buffer, what kind of swirl remover you are useing.
Old 04-21-2007, 04:48 PM
Brian2006's Avatar
Lake country pads are always awesome and I suggest a white pad if it's going with a PC
Old 04-21-2007, 10:03 PM
Gipraw's Avatar
If you are talking about one of those 10" waxmaster type "buffer" .. then you will be just as well off using the swirl remover by hand .. you will get no torque, and no speed out of one of those.
Get yourself a couple of good, terry applicators and go after it by hand ..
If you are doing a large area, I would recommend Tropi-care TC-8 or Meguiar's #2 if you are going to try and remove swirls by hand ..
if it is a small section .. then ScratchX would also be an option.
make sure you follow up with a wax or sealant to protect.
Old 04-22-2007, 12:54 AM
SSideExhLS1's Avatar
3M part #5725 black foam polishing pad, and 3M 05996 foam pad polishing glaze for dark colored cars and 05995 for light colored cars
Old 04-22-2007, 02:52 PM
im using all tropi-care products. I have a high speed would that be better for swirl remover?
Old 04-23-2007, 07:35 AM
Gipraw's Avatar
Yes, if you know how to use it correctly, it would definitely work .. If you aren't experienced with using a high speed on a vehicle's paint .. then I would proceed with extreme caution.
check www.tropi-care.com for their suggestions on what pad to use with a Rotary and their TC-8 swirl cutter.
Old 04-23-2007, 09:28 AM
LS1TECH Sponsor
Steve P's Avatar
Just like Doug said, if you're using a rotary such as a Hitachi, Makita or Dewalt rotary polisher, be very careful with this method.
We have used the black foam pad at speeds up to 1500 RPM for correction in specific situations.
Quick Reply: What type of pad for swirl remover?
