Sponsored by: DashLynx
How to clean throttle body?
Old 06-25-2007, 07:38 AM
1meantransam's Avatar
Default How to clean throttle body?
how do you clean you're throttle body and intake manifold? both are covered in gunk on mine so i need to clean it, didnt know if there was anything special i had to use
Old 06-25-2007, 07:43 AM
02BlackBullet's Avatar
On the throttle body, I personally used brake cleaner. It cleans the **** out of it and then you can scrub the remaining gunk off with some steel wool. I use shop solv on the intake manifold. Before I found that stuff, I sprayed it down with simple green, let it sit for a bit, washed it out and let it dry really well.
Old 06-25-2007, 07:44 AM
so just spray brake cleaner everywhere on the TB? and wipe down and its safe to put back?
Old 06-25-2007, 11:20 AM
smg267's Avatar
I used a wire brush to clean all the build up off the outside of my throttle body. Of course you take it off the car first. Then you can take some super fine sand paper to it and polish it. Finish with some mothers polish that stuff cleans everything. I know they sell throttle body cleaner you can spray into your intake to get rid off some of the build up.
Old 06-25-2007, 01:18 PM
Yeah, take the throttle body off of the car and spray it down with brake cleaner. You can scrub it with a cloth and mothers, some scotch brite, or steel wool. make sure to spray it down again or wash it off with simple green and dry. After that, you can put it right back on the car. Brake cleaner evaporates QUICKLY so you shouldn't have a problem with that. It literally takes 60 seconds TOPS if you soke the throttle body to become fully dry.
Old 06-25-2007, 03:27 PM
SStealth00's Avatar
will this help anything? getting all the gunk out from the inside. like regain lost power?
Old 06-26-2007, 12:51 AM
RickyMartinZ28's Avatar
I cleaned mine on the car very carefully with carb and choke cleaner, got 4 shop rags full of black nastiness outta there, and holy shiznit it made a difference, my throttle response is twice as good as it was before. And yea I regained some lost power and my idler bypass was nearly completely clogged up, my idle is sooo much better.
Old 06-27-2007, 06:01 AM
nitroracer15's Avatar
Don't clean a throttle body with brake clean. EVER. Always use carb cleaner.
Old 06-27-2007, 08:01 AM
ok gotcha, i still havnt cleaned it. i just wiped it out really good for time being. ill pick up some CC in a few days. thanks guys!
Old 06-27-2007, 03:49 PM
2001somws.6's Avatar
^^^^^^Try and do a write up and take pics.^^^^^^^^^
Old 06-27-2007, 04:27 PM
yeah i may do that, good idea
Old 06-27-2007, 04:28 PM
oh and also i can clearly see the gunk go into the manifold area, can i also spray in there also? car on or off lol?... i would take it off and clean but i dont feel like going on a mission let alone i have no time for missions
Old 06-27-2007, 04:41 PM
Its best just to take off the throttle body and intake manifold if you're really wanting to get it super clean, it's not that hard of a job.
Old 06-27-2007, 04:50 PM
i took off the throttle body, that's all of 2 minutes. the manifolds little different
Quick Reply: How to clean throttle body?
